neo campro cps losing engine oil
demomode
30
as per title, my car using liquimoly 10-40 engine oil, oil went missing after 3 - 4K km drive after servicing with new oil. no visible white smoke & no leakage.
izzit engine oil burned bcoz of engine too hot? or other causes?
really need help
really need help
Oil went missing means loosing how many liters?
demomode
30
after service, the oil dip shown at max level (oil level at the top marking) after 3 - 4k km ride, oil dip shown oil level is in between the max & min marking. not sure how many liters gone
KenDiriwan
1,283
225
kendiriwan.multiply.com
Between max & min is a huge gap. Don't think anyone here can guess by how much the lost are.
You need to top it up until max level to know how many liters needed to top up back to max leh, so do that first. If just 0.5 ltr to top up then still rather normal, but if 1 liter or above then considered too much already.
jerrysiow
407
146
Seremban
From what i understand, there is a slightly lower engine oil level after a new service with new oil filter. The engine oil went into the new oil filter causes the level of engine oil drop. You can follow what sifu 6UE5t's suggestion, top up the engine oil and monitor again.
Normally mechanic after start engine and check for leaks, will Switch off, wait a while then check level again. This is to make sure level is correct after filling up oil filter also....:driver:
really need help
If you are using same viscosity before and did not encounter this problem, on next oil change, change back to previous oil brand.
I have a friend encounter this problem before but for him is he changed from 5w-40 to a 5w-30. The viscosity for his car probably to thin, change back to 5w-40 then okay....:driver:
Since when la I become sifu?? :confused:
Both you consider Sifu category edi la. I like your engine 2.5L V6, the sound and power are cun.
I think most will refer us as keyboard warrior......hhahhahahhahah:rofl:
Sifu touge with taufu like Takumi......lol:driver:
I tak pandai touge la, makan touge saja boleh. :biggrin:
Ya just keyboard warrior, only knows skin deep level. :biggrin:
This 2.5 V6 has no sound leh if full std, power also biasa biasa saja coz still normal family sedan. Kena tapau left right center by other cars already.
The 4th generation Clio has received its first facelift after being unveiled few years ago.
What's new?
Engine
The engine lineup comprises of two petrol units, with 89hp and 118hp plus two diesels, producing 89hp and 108hp.
Joining the lineup is a...
