Perodua's first ever sedan, the Bezza finally launched!
RENESIS VIII
7,063
950
Ipoh
The design is to maximize interior space so by going tall they at least increase head room and boot capacity.
---------- Post added at 11:30 AM ---------- 6 hour anti-bump limit - Previous post was at 11:26 AM ----------
Well in any case, it's a small low powered econo car, so just use small rims not exceeding 15'.
Head room sometimes depends on the height of the seats as well. Like the 3rd gen Vios. My head is scraping when I'm sitting on the rear seats. But for my Wira, it doesn't happen even when I try to sit as up right as possible.
If the car is stock, then it shouldn't exceed 15". But if modded in future, anything larger should be better isn't it?
IMHO nope, larger rims doesn't mean better! Proportional to the car size and performance is the better one. Small cars/A&B segments, just use max 16 but 15 is better. C segment max 17 unless got performance like on steroids. D segments max 18 (I'm only using 17 on my Mark X coz still just a normal family sedan, not powerful sports type).
RENESIS VIII
7,063
950
Ipoh
Well, if one wants to go for wider tyres, usually they need to go for larger rims, if not, it might be difficult to find tyres. I'm guessing your 17" on Mark X are on wider tyres isn't it? Instead of the usual 215mm width.
Yes, front is 225/50/17 and rear is 245/45/17, upgrade from std 215/60/16 of my non sports package Mark X version. Note that std on the sports package Mark X is already 225/45/18, so mine is 1 inch smaller diameter than that.
30,002
I thought max can only reach 15" as the car is based on Axia. Since Axia's category is like Viva.
Always have hero one mah! Many will go over what is max recommended.....lol:biggrin:
---------- Post added at 06:36 PM ---------- 6 hour anti-bump limit - Previous post was at 06:04 PM ----------
Polo GTi is on 17" woh!......:driver:
Polo GTI got decent power & performance leh, pretty fast car, so still ok.
RENESIS VIII
7,063
950
Ipoh
Won't it be a bit troublesome sourcing different sizes for both your front and rear tyres? Why din't you go for same size with the front?
And use tyres profile that is too thin. I saw before Suzuki Swift on 205/40/17. The sidewall profile is just so thin.
Perhaps sometime in future when Bezza gets older, somebody might just put in a K3-VET into it... 215/40/17 should be useful for that engine...
30,002
Not only sourcing tyres but tyre cannot rotate also....
Many use larger rims and lower profile for looks only....:driver:
---------- Post added at 09:31 PM ---------- 6 hour anti-bump limit - Previous post was at 09:30 PM ----------
But time to change tyres most will make noise, like my friend using Mazda 6 on 19".....lol
RENESIS VIII
7,063
950
Ipoh
Can't rotate means the rear might fade faster than front due to Mark X being RWD....
Hmm just a bit for the front as I prefer 225/50/17 which not all high performance tires have. The rear is easy to find. Well I want bigger traction at the rear while 225 at the rear seems a bit smallish/narrow. Then the other reason is because I found this forged Prodrive rims that is very rare and in staggered sizes (7.5fr, 8.5rr) with offsets just nice for my car, so then I'd need staggered tires. Maybe later if I got budget and can find equally good replacement rims that I like with size 8.5 all round then I'd put 245 all round or at least 235 (depending if 17' or 18').
[/COLOR]
Yah now can only rotate left/right using asymmetric tires. Last time cannot even rotate at all without dismantling the tires coz I was using directional tires!
Yup, if I have that Polo GTI, I'd probably downgrade it to 16' but then more limited choices forUHP tires! For Mazda 6, I'd probably just use 17', max 18x8 with 235 tires. 19' is just ridiculous for such a car!
Hmm not really, front may still wear out faster or at least almost even since it's used for braking and turning. But if you often drift/do burn outs then yeah the rear may wear out faster.
RENESIS VIII
7,063
950
Ipoh
Well, on another thread regarding 225/45/18 tyres that I started, my friend was considering 19" ori Vossen wheels for his F30 320i. Since you said 19" for Mazda 6 is ridiculous, I guess that is even more redundant in 320i.
We change Bezza thread into tyre talk already......lol
Well, we can talk about the tyres used in Bezza. I'm surprised that Perodua changed their factory tyres again in the high spec Bezza. Using Bridgestone Ecopia now. Lower spec 1.0 models are using
Silverstone Kruizer. Axia I know that they are using Hankook Kinergy, while facelift Myvi had changed into Goodyear Duraplus.
From what I remembered, previously all their cars are using Silverstone Synergy but what's with the recent changes?
30,002
If he already complain 18" is bumpy better not 19".....lol
Tyre change all depends on tyre supplier, anyway all are eco or entry level tyres....:driver:
RENESIS VIII
7,063
950
Ipoh
Hahaha, he din't complain about bumpy, but road noise instead.
So, all of these will have almost the same kind of performance?
19' should be used by bigger/more powerful cars. If used by D segments or smaller cars, then tires become too thin and uncomfortable. If used by just normal power cars then it's actually wasting power unnecessarily. All in all it just make the car not as good as it's supposed to be just for the sake of style/image.
A Post Every 5 Mins
Hi,
Im just curious, based on my recent and previous experience, I noticed these seemingly nice sales man will end up screwing up their sales by being pushy; in my case at least la. Does it really work in securing sales being so pushy?? whats their intention?? to makan deposit when people change their mind??
I recently decide to look for a ride since I got a nice number plate. I thought times have change and car sales man would be more professional and more refine. In all 3 place I...
