Car Swerves When Accelerates
tuileihai
Mar 31, 2015
34
508
After I had my car wheels balancing and alignment done, when I accelerated my car, it started to swerve light and right. My steering wheel had no control over it. It happened every now and then.
Where is the possible problem?
tuileihai
34
508
When I pressed on the accelerator, and as the car picked up, I can feel the whole car slightly swerving left and right on its own momentarily. It is an old Proton Iswara.
But why right after balancing and alignment? Or maybe did not tighten something....:rolleyes:
tuileihai
34
508
Before I did my balancing and alignment, I noticed at times the steering shaking lightly and I let go of my hands from the steering wheel, it would slowly swerved towards the left side.
That was the reason I sent my car for wheel balancing and alignment. And now I found out this new problem. The swerving movement is as if my car being lifted up by strong gust of wind or speeding thru' a big patch of water on the road.
Tom
TIMETOATTACK
Jul 6, 2000
5,562
3,229
there is definitely something seriously wrong.
A quick video would help us help you identify the problem
Shinjite
864
120
Klang
TLH, go to another alignment shop to get a second opinion
Go get a 2nd opinion and redo alignment.
Initially I thought it was torque steer until I saw what car you drove then that thought went out the window. Unless you have a 4G63T inside?
And what RPM do you experience this swerving? Do you feel it even when driving slow or only when you accelerate hard?
KenDiriwan
1,283
225
kendiriwan.multiply.com
Exact feeling right here, was deeply curious to know the powertrain but oh well.
hi all,
I've recently installed new set of different engine into my pV6. previously i;m using tenon 2-way communication alarm. After rewiring my mech told me that he doesn't know how to wire correctly the tenon alarm with the turbo timer. so he asked me to bring the module to accessories shop and put it back. I did search thru forum and understand that some alarm cannot be coupled with turbo timer. It will pening. I think my tenon also might not work with the turbo timer plus I don't know...
