Can new Wira 1.6l (M) gearbox still be found?
Progen
Aug 26, 2015
11
I was speaking to a mechanic the other day about replacing the worn synchromesh and he said not to bother with reconditioned ones with limited warranty and go for a new one around RM2,000+ instead.
The thing is other mechanics I've spoken to can only get the reconditioned ones and I can't go to the first mechanic because he's in another town.
"New" gearbox is not impossible. But for 2000 that's somewhat cheap for new. How much are the reconditioned ones?
He could be passing the recon off as new for that price....
Why not repair your old one instead.....
ken yeang
6,617
1,327
nowdays, repair and recon very hard to differential......as these stuff are passed on and over another.
Like bro vr2turbo asked, why not repair it? Manual trans is easier to fix, esp the wira model. (i smell the mechanic dono fixing g-box, so he proposed changing nother g-box and he gets the business eventually).
Autobox fixing can cost a lot more to fix....
I have seen my mechanic fixing many types of auto gear box and you are right, many mechanics nowadays get recon unit, remove your old one then fit in recon one...kaotim
Old one send to recon wait for next victim......lol
ken yeang
6,617
1,327
Hahahaha, some mechanics nowdays only good with swapping parts......not fixing anymore.
They shouldn't have name their shop "Kedai Baiki Kereta", instead call in "Kedai Tukar Barang"
Yup, same in many other category, like PCB. Faulty change whole board, whereas if know the technician he find which diode or capacitor that is faulty, and just change that....:biggrin:
Progen
11
I was going through some posts and owners were saying that it costs lower RM1,000, inclusive of labour, to change all the synchromesh gears which was why I thought if there were really new ones for RM2,000+, then I'll be going for those. I've seen auto gearboxes advertised as new and guaranteed to be new instead of reconditioned so was wondering why aren't there any new manual ones.
That is because cars are all going auto. There are model without manual option even.
Anyway, why do you need to change all the synchromesh? Are all gears difficult to engage? Usually synchromesh for one gear will go faulty, and not all. My VR MT gear box I have changed the 2nd gear synchromesh before....:rolleyes:
DanzEterna
15,911
3,371
www.primeperdanaclub.com
there is no such thing as new gearbox, even if there is will costs u a bomb,
those in the market are reconditioned ones, using new parts. must ask them what they mean by "new gearbox".
the best way is to get a used gearbox from halfcut & just install it.
ken yeang
6,617
1,327
with the right tools, one can even swap a car gearbox in the backyard of the house...
Ppl have swapped engine in their own garage, so gearbox should be simpler.
WRC team change them in a couple of minutes only......hhahahhahahaha
g88
3,081
54
5,148
my experience of 'repairing' gearbox is basically replacing each/some of your gear bearing...and the output will be your gearbox will be more noisy...reason very simply...imagine now you said your 3rd gear is bit loose etc...and you only replacing your 3rd gear bearing and so call 'tighten' it...same time it pressured your others gear which the gigi already makan....
SO in order to rectify this, you basically need a brand new gearbox where all 5 gears, reverse gear, bearing, shaft all new...else no point fixing them...
A Rm2000+ to me is a halfcut gearbox...recond or not...depend your luck... i would spend looking for one which is from halfcut and look at the external case condtion and all the gear level...to 'try' guess the condition...final outcome only know once you installed into your car...but certain necessary need change like flywheel bearing etc...
BTw, what problem with your 1.6 gearbox ? 5th kick ? make sure you get the SAME code gearbox as ratio is different...SOHC, DOHC, Mivec....
Progen
11
Having clunking / grinding sound with the following changes
Neutral to 1st
3rd to 4th
4th to 3rd
2nd to 3rd also not that smooth
Definitely synchromesh problem because it's fine if I double clutch but that defeats the purpose of having synchromesh invented in the first place. :D
ps. 4th to 5th and vice versa is fine.
The GT channel dubs and subtitles an older video of an RB engine and Skyline engine. The video features its racing heritage and legacy since the late 60's. Keiichi Tsuchiya grew up admiring the Skyline's since his early spectator days in the Fuji Speedway Circuit. Also, there's this homemade R32 mesh with R34 made by a Skyline enthusiast, in hopes of entering the D1 Drift series. Check out his...
