Myvi adjustable, disc brake,handling part repair.
mhdalef
Jan 18, 2015
26
I wanted to change my absorber,disc brake and some of handling part. But I want to use my credit card to do it. Any suggestion around pj or sunway area.
Sent from my iPhone using Tapatalk
ixeo
4,788
3,080
KL, Malaysia
Kakimoto Sunway.
But I wouldn't go there even if you paid me.
Why Sunway? Give EA Autoworks a call in Bukit Jalil and set an appointment. They'll set you up with rotors, ultraracing bars, suspension and stuff. Look for Drex Chan.
ixeo
4,788
3,080
KL, Malaysia
Because that public road has the most horsepower in Malaysia... Sepang Circuit is not a public road...
mhdalef
26
Do you mind if I ask for his contact number?
My car was a Mitsubishi Lancel EL 1996 with 4G13 engine, Variable Venturi Carburator or Piston Type Carb. It's similar to your Proton Wira in Malaysia.
Two your ago I've bought an Electronic Controlled Mikuni 2Barrel Carburator with Intake manifold for my car. But the Electronic Control Module was not included and therefore not able to install in my car.
Recently a friend have swapped his ECU from his Mitsubishi Lancer with 4G15 EFI engine with my old 4G15 engine block and add some...
