daihatsu charade g100 steering not return
dewagame
Nov 1, 2014
16
i have installed an engine from toyota starlet(4efte) on my car. i’m using the original g100 knuckle and every thing that install with it i.e. lower arm, suspension, sway bar....but the steering rack is from toyota starlet.
the problem is my steering does not return to original state(center) after i’m taking a corner just like other car..
help me sifus
charade starlet
ken yeang
6,617
1,327
wheel allignment sudah lari....Send to tyre shop to sort it out, bro
dewagame
16
i have sent for alignment..and change front tyre...balancing...but still dont return
There's another possibility - your power steering rack is spoilt. It's supposed to have some sort of tension when you turn, is there any tension at all or does it even try to return back to middle? These cases it's cheaper to replace with a halfcut
john_unai
371
80
mtkb
I have exactly the same problem with my car. half turn is ok, more than that the steering wont return. when i ask foremen, he said maybe because my tyre is wide causing this problem. I just ignore it since i already use to it.:driver:
Kopi
875
15
3,018
Cheras
Are you using suspension with bodyshift?
dewagame
16
is it solved now...first what should i do..check the steering rack or...and one more question.....is this problem can be solved?...
ken yeang
6,617
1,327
Firstly, it sounded like the TS has found answer..........but then he posed a question?? hmmm
dewagame
16
confused?? i just wanna know does this problem can be solve or not? thanks for iur feedback:-)
---------- Post added at 02:18 PM ---------- 6 hour anti-bump limit - Previous post was at 02:17 PM ----------
sorry for my bad english
Mar 8, 2013
4
ok
i have installed an engine from toyota starlet(4efte) on my car. i’m using the original g100 knuckle and every thing that install with it i.e. lower arm, suspension, sway bar....but the steering rack is from toyota starlet. the problem is my steering does not return to original state(center) after i’m taking a corner just like other car.. help me sifus charade starlet
upppppppppppppppppppppp phụ chủ thớt
help me sifus
charade starlet
Is the steering heavy? So you only change the engine and steering rack only. Was it plug and play or did you need to mod it in?
Usually self centering for steering is the caster angle. Check whether this was changed during the mod?
Since you mentioned everything else is still the g100, looks most likely to be the rack problem.:smokin:
dewagame
16
Thanks,
U help me fix it..
Helping a friend whom lost his satria 3 weeks back at subang area.
- Silver color
- 1.6 Auto
- 15'' Sport rim & lowered
- Reg number :- JET 2221
very obvious looking cause the front bonnet is in black color ( those bought from shop
before spray type)
Please help for a look out. thanks.
