this look like axiaI don't know about what others think but I feel that 2nd generation Toyota Passo looks uglier than Myvi.
Because they are all based on Toyota/Daihatsu's range of budget compact cars. Even Axia had a Toyota variant.this look like axia
You all make the TS runawayHi, I need some advice on what upgrades I should get for MyVi Extreme (2013). As this is my first car I'm not that familiar with all of this. I appreciate any advice given. Thanks in advance :)
pls tell me I'm not the only one that thinks the MyVi looks hell alot better than that.this look like axia
Thanks for your wise words sir is/are there any specific brand recommendations I should know off?You all make the TS runaway
Since its your first car, I assume that you just started to exposed yourself into this modification scene. The advice we give is only for your reference / guide, If you are into the stuffs that you want to mod your vehicle, there is no way we can change your mind. You will be gaining experience slowly while on the process. Newbie always will go for looks more than function, and slowly either you stop or you will be heading into function mods.
Who you hang out with effects what you will be doing on your car.
If this car is mine.
Full sets of Ultra Racing Bars, if on budget. Then just fix those important one.
15'' with some decent rubber, if on budget. Save some money first, tires effect most.
Then will go for adjustable, if on budget again. Get some performance shock & spring. Not lowerd spring or potong spring arr.
Full set piping from front to rear, please visit much more experience exhaust shop.
By this kind of mod, your car can't go faster. But its you, that can go faster. IMO..
Get a pair of decent 15" rims, and then get a set of Potenza RE002's!pls tell me I'm not the only one that thinks the MyVi looks hell alot better than that.
If I got contact for Yoko, or Toyo. I would end up at AD08 or R1R.Get a pair of decent 15" rims, and then get a set of Potenza RE002's!
Just so you know, Tek Ming is selling R1Rs at 309 a piece including installation and balancing.If I got contact for Yoko, or Toyo. I would end up at AD08 or R1R.
Stopppp. My RE002 still have 95% of thread. :rolleyes: And I already can get below that price for R1R. Just that still not cheap.Just so you know, Tek Ming is selling R1Rs at 309 a piece including installation and balancing.
That is your aim......Get a pair of decent 15" rims, and then get a set of Potenza RE002's!
Including installation and yada? Why aren't you getting it yet?Stopppp. My RE002 still have 95% of thread. :rolleyes: And I already can get below that price for R1R.
Since you are new research the tyres more before buying. Don't regret later.....I should go for R1R I'm presuming?
Its because on that time, I was fixing the new RE002 with the new rims. Then I ask about R1R's when my car is ready.Including installation and yada? Why aren't you getting it yet?
Also, jchooo, I'll call you OP here. Ehh not necessarily. It's an extreme tyre. Very good grip on dry, but quite the bad in rain. You might want to do some research on tyres first. Heh.
Change on the spot maaaah! Eh bro I thought you were selling them 002's? :rolleyes:Its because on that time, I was fixing the new RE002 with the new rims. Then I ask about R1R's when my car is ready.
Waait then what's your recommendation for balanced tyres? Cos I don't think I'll be changing tyres often :xIncluding installation and yada? Why aren't you getting it yet?
