Myvi 1.3 Ezi lagi best: Where you usually install the DRL?
scoutfai
Nov 3, 2013
18
5
503
Referring to this Myvi type:
Usually which location at the front will you install the DRL?
Unlike the Myvi 1.3 SE which has the Myvi 1.5 SE front bumper, Myvi1.3 SE can easily choose to install it at top or bottom of the foglamp. The design of the foglamp cover of Myvi 1.3 SE just make a DRL installed there nicely fit to the existing front bumper.
But for Myvi 1.3 Ezi does not enjoy this advantage. I have seen ppl install it on the far side end of the lower black grill, but I personally feel not my preference (of course is a subjective matter). Curious to know other Myvi 1.3 Ezi owner where you usually install it.
Other installation locations that I have seen on the street before are:
1) Around the upper headlamp perimeter
2) On the upper front grill.
3) On the lower front grill.
4) Installed inside the side mirror turn signal lamp.
cvkit17
2,884
1,354
Own preference brah, but I got a suggestion. Install at the lips just below the fog lamp. But you gonna cut a hole first
scoutfai
18
5
503
Yes, couldn't agree more it is completely personal preference. Just curious and survey see got other creative location thought out by other owner.
Do you mean at the red square I circle at the following picture?
If that is the case then this is quite big "sacrifice". Hope no need drill holes on painted part. Having it so close to foglamp, I think if go with this suggestion, probably will more willing to go with foglamp ring LED or CCFL. Saw some ppl did it. But it seems like the ring light strength degrade very fast, same car few months later I already see the light dim at one side.
I was once have an idea to install it at the green square location at the picture above.
Supra_Fanatics
20,673
3,998
Certain cars just dont look good with DRLs :biggrin:
scoutfai
18
5
503
no need to install :biggrin:
kena ada semangat DIY. :biggrin:
---------- Post added at 09:13 PM ---------- 6 hour anti-bump limit - Previous post was at 09:11 PM ----------
Scouting kah? haha
Surveying what creativity other owner has.
---------- Post added at 09:14 PM ---------- 6 hour anti-bump limit - Previous post was at 09:13 PM ----------
Agree, since at the beginning of styling such lighting element is not put into consideration by the designer.
my brake got sound when i didn step on it..erm..i just change to l2 brake disc rotor and caliper. got some eeeeeeee sound when my car running...but when i apply brake, even just a little, the brake wont sound anymore..anyone know y?
