Inspira 2.0 CVT Bolt On Turbo
Waiora_ProTuner
619
221
Jatco CVT can withstand the torque...I believe it use the same CVT as in 2.4L Lancer (4B12)..
It's safe to say that it can handle 170hp with 230nm..around 0.2bar or 3 psi...LOL..
just need to control the temperature...bigger cooler maybe..
hon_cs
251
43
3,028
Ipoh
Previous post stated boost for not more than 5 minutes, now posting less than a minute plus show off? If u meant bot is for show off, then u must still be living in a world shielded by a cover the size of a peanut, no offence to u mate but offence noted from your statement above though. There tons of bot out there and it's been donkey years since bot was introduced thus if u still can't figure out the purpose nor the benefit of bot by all means keep to your na and your inconstructive comments are unwelcomed here so no thank you.:smokin:
Owner is asking cvt bot. Not conventional auto/manual. No offend but do you own cvt car or inspira/lgt? If not don't simply quote my statement wrong. Your video is showing 1.8 manual. I don't want to argue about 5 min pull. A good reference is one round of cameron/genting drive would boost your car more than 5min on and off.
zack.my
Jul 10, 2013
42
508
Maybe out off topic..i am inspira 1.8 m/t..
Think to put BOT..
Any sifu here suggest me..is it ok for me to put BOT ?
Cant pull more than 5min mean what?
As i know this thing already set for safety area boost presure.. 0.6bar.
Minimum enuf..so presure must be cant be more than 0.6 right?
let say i pull over 5min..let say 10 min.. What happen?
Sory noob user here..plis some body answer my question..
1 more thing any recomended other shop speedworks?
Think to put BOT..
0.6 bar already in high range....safe for basic bot below 0.4bar
thanks for quick reply..
ok let say 0.4bar...
then cant stand more than 5min?
hahaha..
any inspira 1.8mt put BOT already? is it worth every buck on it?
Manual should be okay, more worried the power too much to handle for CVT gb....
zack.my
Jul 10, 2013
42
508
should be okay..mean totaly ok right?..
i do some research mt gb on inspira can max 0.7 bar ..without melt their piston
but for more peace of mind and not too pressure on engine better put 0.6 bar..
and for more secure and less wear n tear can just put 0.4 only..it is true?
i am still waiting for real inspira 1.8 mt include BOT...
in malaysia just speedworks only provide this BOT installation?
another suggestion?:confused:
hahaha..
its all depend on engine ignition+fuel tuning as well as radiator capacity and other cooling capacity
any 1 can advise engine to swap into an Opel?
it's a FF , did read from foreign site, sr-20 , 3s-gte can go in.
but not sure wht did they done on the enjin
any 1 experience this or ur tuner modd and Calibra b4? kindly advise, thank you
