My ceFIRO
weikee
924
15
Maybe is the afm. Had this problem twice. I clean the AFM with CRC contact cleaner (non oil based).
I have a spare AFM, just clean the AFM with CRC and let it dry for few hours, then swap out my car AFM. Keep the dirty AFM in the store.
VQ20DE
Oct 10, 2013
20
finally my car infected with idle rpm dropping problem... :banghead:
is your problem same as mine? my cefiro rpm will drop to below 500rpm sometimes engine dies when i shift to N to coast. but only happens when engine cold, after driving for sometime, it's ok.
seizai
937
driving time ok, only during idle...
drop till almost engine stop :confused:
weikee
924
15
Mine happen after engine fully warm up, and drove for minimal 20mins. Think the engine bay heat may have heat up the AFM making it go crazy. The car feel sluggish, and RPM may drop when you try to accelerate from standstill.
---------- Post added at 01:05 AM ---------- 6 hour anti-bump limit - Previous post was at 01:04 AM ----------
AAC dirty may cause idling problem too.
The Scuderi split-cycle engine is intended to be an improvement on the traditional Otto cycle and acts a bit like the Miller cycle. Instead of using a mechanical supercharger, though, the Scuderi design uses paired cylinders to compress air, which is then used to prevent reversion of the exhaust gases into the intake tract. It is also possible to store some of this compressed air to power the vehicle as part of a hybrid drivetrain...
