When you mention changing cv joints do you change the whole cv joints and the driveshaft coz I suspect your driveshaft is bent... try to get the whole set (driveshaft plus cv joints) and see what happens. In your country , do you have wreckers shop whereby they sells secondhand auto parts from japan ?hey SB3
i have on 20's right now and adjustable d2 shocka dn soring coilovers....but the car once lowered to the tired height or even a little higher still causes the joints to fail...i dnt knw if the symetry of the vehicle is off but i see a lot of these lowered very low all over the net i was wondering if there is a shorter axle or better bigger cv joint ppl use...
you changed part, i changed carchange new part
change new part
brand is stated at box...hi seizai, is that from eagle eye TW?
mine's getting dimmer as well, but am planning to mod to projector lens for a change...
haha, yea, it came across my mind too, but then again i'd go for safety first rather than having dim lights.brand is stated at box...
I was thinking about tat.. but can't fit in hid... takut saman
HID std should be 35W, r u sure it is 40W?seizai, am getting the pj3 bi-xenon with 40W 4300k HID, seen the performance, great for my night travellings on PLUS....
yup, saw the ballast with my own eyes, comes with 1 year warranty, should be ok, since there are so many guinea pigs out there using it already....HID std should be 35W, r u sure it is 40W?
