My ceFIRO
weikee
924
15
Maybe is the afm. Had this problem twice. I clean the AFM with CRC contact cleaner (non oil based).
I have a spare AFM, just clean the AFM with CRC and let it dry for few hours, then swap out my car AFM. Keep the dirty AFM in the store.
VQ20DE
Oct 10, 2013
20
finally my car infected with idle rpm dropping problem... :banghead:
is your problem same as mine? my cefiro rpm will drop to below 500rpm sometimes engine dies when i shift to N to coast. but only happens when engine cold, after driving for sometime, it's ok.
seizai
937
driving time ok, only during idle...
drop till almost engine stop :confused:
weikee
924
15
Mine happen after engine fully warm up, and drove for minimal 20mins. Think the engine bay heat may have heat up the AFM making it go crazy. The car feel sluggish, and RPM may drop when you try to accelerate from standstill.
---------- Post added at 01:05 AM ---------- 6 hour anti-bump limit - Previous post was at 01:04 AM ----------
AAC dirty may cause idling problem too.
hi all,
im interested in modifying the head. my plan is to not widen the port size as its a small 1.0L engine and i have no intention of getting bigger intake manifold and TB. i also dont plan to smooth out the intake and polishing the exhaust as i already touched the ports and its not that rough with quite even surface, so i thought i could save money on that
i would like to do 3 angle valve job, intake port matching and milling the head, keeping the port size stock in hope of...
