need help (got kluk kluk sound from back myvi 1.5)
Jun 12, 2012
need help got kluk kluk sound at the back absorber. the sound only appear when there is a pothole on the road or a very uneven road. i'm currently using gab ss (hi lo soft hard). i already went to few shop. this is what they do
-already check absorber (nothing wrong with it)
-already tighten the ur arb
-already tighten all the screw
still got that sound. my suspect is either bush or the thing that holding the absorber
need help from sifu.
fazidk
413
5,183
U can get d originals from spare part shops OR aftermarket ones at performance outlets or even have custom ones (I know one here in Balakong)..
If it's klok klok klok, I'm 90% sure it's the top absorber mounting. When you changed to the adjustables, did you change the absorber mounting? If not you're gonna get klok klok klok noises
fazidk
413
5,183
Oh ya that too...d sifu has spoken :):adore:
Bro. Izso,
Due to what? Loose? My adjustable using the car original abs mounting too? But of course no sound ...:biggrin:
Bro. Izso,
Your car different species la. Myvi absorber mounts are made of jello. For my Myvi, the mounts die faster than the absorbers. Now after 7 years the springs are finally dead. Absorbers changed 3 times and mounts 3 times together with the absorbers
jerrysiow
407
146
Seremban
Hi TS, it's normal if u changed to adjustable suspension which the rear top suspension mount (it's metal and the function of it is to adjust the H & L of the spring in the rear). Because it's a metal, it will make some noise when ur car in full load or in uneven load. I think ur bush is fine and no need to change it.
Btw, I;ve use to it edi :)
I normally have problems with my front mountings.....
The Marketplace Top Posts
custom pu bumper lip/DIFFUSER cefiro a33 jb/kl
Im interested in looking for a custom lip pu material for my car cefiro a33 bumper. I recently installed a true quad tip exhaust and sadly it looks retarded and fake from far view. Any place recommendations? Jb or kl
