Knuckle conversion from 4 lugs to 5 lugs
cpmah
348
5
SELANGOR
Hi sifu here,
I am looking for 5 hole knuckle (REAR) for Perdana, anybody here know which model of car should I get (for PnP into Perdana)?
TQ!
NeuroOne
WFH
2,074
181
Putrajaya
Hi sifu here,
TQ!
i guess the hub from FWD galant or eterna.
dont get it from 4WD, the hub wont fit.
NeuroOne
WFH
2,074
181
Putrajaya
:itsme:
The FWD version of eterna or galant got 5 X 114 model?
well, i'm not sure about that.
coz before this, i only get the 5x114 hub from a 4WD galant which do not fit the rear.
in the end, i tebuk the rear hub to be 5x114..
Hadi17
145
10
Johor
Hi sifu here,
TQ!
u can try doing it in Era Maju .. they can change your current 4 knuckles to 5..
my uncle had a perdana and did the same .. 7 years and already n no problems ..:proud:
n cheaper for sure !!
try search for lan automotive engineering in mudah.my....
selangor area..but couldn't remember which area
aHLengChai
380
53
Hi alls.. just wonder the other side.. mine is oem 5 knuckles wheel.. but I want to convert to 4 knuckles.. since alot size and choices of sport rim in our country that using 4 knuckles.. so is it possibles?
Ha? Why? What car do you drive? Also 5 x 100pcd vs 4 x 100pcd not much difference in terms of rim choices mah. Unless you talking about Peugeot or BMW PCD, that's quite rare.
Anyway if stock is 5, it's 5 for a reason. More strength to hold the wheels. Reducing it down to 4 is a bad idea
PCD 100 and 114.3 whether 4 or 5 lugs are quite common, right? If not, then go 10 holes or 8 holes, my rims on VR and Hyundai are both 8 holes so can fit both 4 x 100 and 4 x 114.3......
sweelt
Nov 6, 2016
2,306
248
what wheel size ? many choices available 5x114/100.
Just outside my house compound at PJS 9/10 Sunway, 2nd september (due to no space...hv to park outside lol). That morning found out that all my sport rims (4 pcs) missing. Damn it! My advice, install good shock+motion sensor on your car. Now, i have install 2 shock+1 motion sensor at my fish. Damn sensitive!
