Knuckle conversion from 4 lugs to 5 lugs
NeuroOne
WFH
2,074
181
Putrajaya
means take out brake disc n caliper perdana and replace with vrg is it
sorry so much question... newbie :biggrin:
yep. just replace the disc and caliper.
but the VRG disc and caliper u got is 4 lugs or 5 lugs?
if 5 lugs, then u kena tebuk la ur Perdana hub..
anyway, mane dapat? berapa?
LowKey2677
165
Any modifications needed if i were to fit a complete FTO brake set to a 1.5 wira? Im planning to change from 4x100 to 5x114.3. Any idea of whats the best way to go?
LowKey2677
165
Danz, the reason im thinking of changing to FTO brakes is because its 5x114.3. I have a set of wheels that i would like to fit which is 5x114.3. Whats the cheapest way of converting to 5 lugs? If tebuk lobang also need to change the knuckle rite.
l2s_turbo
1,068
154
3,163
Knuckle no need to change..
GRexer
GRexer™ KuzTomZ
1,199
10
Puchong
LowKey2677, if Wira to FTO, just swap the whole set, front inclusive of knuckle, rear inclusive of lower arm, plug and play.
LowKey2677
165
Would there be any fittament issue after changing to FTO brakes? Read somewhere that someone changed to FTO setup and his wheels are sticking out from the fender due to bigger calipers. What are the PRO n CONs if i tebok lobang VS changing to FTO brakes?
Thank you, in advance, for all your assistance in this matter.
DanzEterna
15,911
3,371
3,213
PJ
www.primeperdanaclub.com
of course changing to FTO knuckle itself is better than tebuk the hub, as human error might occur sometimes,
if the holes are not accurate u may face rims not fitting properly or wobbling.
^pomen_GTR^
7,000 RPM
7,509
1,690
The Mines
some design of 15" rim wouldn't fit....so in general i would say minimum is 16" rim....
ermm im currently riding on a b16a.....it seems to be not enough for me due to performance wise but there is limited $$$....(sigh) maybe around 1k to 2k.....what should i do best wit my car ? change block ??racing clutch ? racing cam ??
