Muffler barely any sound?
DerrickEe
98
9
508
Hi guys, about last month, I installed a Borla straight flow muffler on my car, and yes it was very loud and bassy initially. Last week my hands were itchy and decided to install a DIY cold air intake, the DIY was okay, but I removed them about two days later because of the heavy rain recently in my area,afraid of floods,since the road I travel to college is prone to flooding. (Ps: I never really pay any attention to the sound of muffler when my CAI was installed)
Until now,I have not installed the CAI back. And I just noticed that I can barely hear any sound coming from my muffler, but only when I high rev.
So does anyone know what is the cause? Is it because of the CAI? Or is it normal for mufflers to produce less sound over time? Big thank you to anyone that can help me out :smile:
Are you sure the original sound you heard was from your exhaust? Maybe what you heard earlier was intake noise?
DerrickEe
98
9
508
Nope, I'm very sure the original sound I heard was from the rear section. Because when I first got my muffler installed, I was running stock without CAI. Only after I install and then remove the CAI, I cant hear anything from the rear section anymore :S Weird.
D7zul
2,697
848
Shah Alam
mayb ur muffler got water inside thus making it not noisy :biggrin:
Never encountered such issue before. But I think it makes it better, don't you think? :)
neohadri
200
34
experience any power drop ? usually muffler will be louder over time
DerrickEe
98
9
508
means run-in already.
Ohh,any solution to this problem? :S
Oh no :( Any possible ways to get rid of the water for now?
Hmmm as for me,I installed the muffler for purely cosmetic purposes,so that isnt really a good thing for me :S
Power drop,yeap! Low end torque especially.
Maybe you've already use to your muffler sound after few weeks.:rofl:
Hahahaha no no,it really became very silent all of a sudden :rofl:
Dayline668
1,810
492
1,683
When u replace your muffler or CAI did u do a ecu reset..? The change u made changed the A/F ratio, richer the car run the louder the sound(always louder when cold start) the ecu need run few km to relearn the correct A/F ratio(reset your ecu will regain your power back). Mine subaru exhaust when install sounds loud but now settle down to a sporty sound which suite my sleeper car.
added.
When the exhaust system is new, the inner side is silky smooth, after some driving, the inner side will fill with carbon deposit which will dampen the sound. The longer u use the louder is starting to kaput la...
DerrickEe
98
9
508
added.
Wow thank you for your explanation, I did a test run just now (on a sunny and dry weather), surprisingly the sound was back to its original sound :confused: I think it must be the weather and humidity that caused the lack of sound? And as for power wise, it was back to normal. I wonder whats up with my muffler...
Nope, when I installed my CAI, i didnt do anything besides plug and play :) Currently my intake is running stock, perhaps reinstalling the CAI after this rainy season is over :)
In the muffler probably fiber glass as damping material, but straight thru' muffler should not be affected much.....
Hey guys, i hav just install a twin barrel mikuni carburator in my wira 4g15...the throttle respond seems even worse than my stock carburator le...haih...the secondery only open after 3k while throttle more than 2/1...below 3k rpm i tekan habis the secondery also wont open..haiz..issit normal? top speed decrease, from 185 to 165km/h.........one thing really disapoint me is, all my friend said that my car has less pick up....even when the secondery open, the pull of the engine also has no...
