Bro. Dayline,For braking power bigger master pump, brake pedal feel brake stopper, better brake pad don't mean racing pad, bendix pad is very good upgrade for stock brake that dun make race pad squeak...
Have trestor on kenari for some time, now the rotor condition is started to eat unbalance, so bendix is still better on rotor friendly so far. Next will try DON.Bro. Dayline,
Try Trestor Blue Advantage. I have been loyal Bendix user from Metal King Plus, Metal King Gold and Metal King Titanium and now on the Trestor. The cold bite is so much better, and even the overall bite is very much better, however the rims turn black with brake dust very fast. For me Bendix about a week to turn black but with Trestor 3 days already black.....
what is a brake stopper?For braking power bigger master pump, brake pedal feel brake stopper, better brake pad don't mean racing pad, bendix pad is very good upgrade for stock brake that dun make race pad squeak...
Which model of Trestor? Normal, semi metallic or blue advantage? Actually Trestor and Bendix from same local manufacturer...Have trestor on kenari for some time, now the rotor condition is started to eat unbalance, so bendix is still better on rotor friendly so far. Next will try DON.
1. Are the brakes spongy? If yes, try flushing the brake systemThanks! I'm quite noob with brakes. I've got a question. I have aftermarket front and rear brake pads on my inspira. The car now has definitely more stopping power but sometimes I need to press the pedal MORE to achieve a certain threshold. Sometimes I can press the pedal LESS to achieve that same threshold. The car is less than a year old.
What is this caused by and how can I rectify it? Thank you!
Brake stopper works like giving u more harder pedal feel by minimizing firewall flexing when u pressing the pedal, give u more precise control over braking.Could you elaborate a little how this brake stopper works to improve braking performance?
Thanks.
High temp pad need to warm up for better bite, when cold they feel like slipping but when they get hotter the better it bite. U need to test when do the problem came..?Thanks! I'm quite noob with brakes. I've got a question. I have aftermarket front and rear brake pads on my inspira. The car now has definitely more stopping power but sometimes I need to press the pedal MORE to achieve a certain threshold. Sometimes I can press the pedal LESS to achieve that same threshold. The car is less than a year old.
U can try better pad 1st since your stock brake r huge, note that harder pad will eat rotor fast but will give u more braking power.Aiya, I forgot to mention about my wife's car. It is a Chevrolet Captiva. SUV with heavier weight, softer tires and softer + longer travelling suspension compare to normal car. I have brake stopper on my other car and don't think it will help much on the Captiva situation. Even slam the brake, I can feel the car inertial is too much over the braking power (tire no screaming but rolling smoothly). Master cylinder is something can try out but not easy to get a suitable one. Bigger bore, more power but respond slower and need to step very hard. Smaller bore easy to press but the power is not sufficient. There was a vacuum cylinder thing to add onto the brake booster (black round thing behind the master cylinder) but I'm not sure how far it can go. I only know an evo booster put on wira can increase the braking power until you can really feel it.
My main problem is, I wanted to put a set (front and rear) evo 4-6 ori brembo caliper onto the car but the ori brake caliper already almost touching the 17" wheel inner diameter. I don't think it will help much. To get a new set of VTTR which big enough to solve my problem, I need to replace all 4 wheels to 18" and tires. The cost is a bit stiff for overall gain. Now I can only blame the car is not hot enough to make the aftermarket manufacturers to put something for it into the market, example like Brembo Max slotted rotors (few hundred a pair) or etc.
If anyone knows any brake specialist workshop or so, please let me know so that I can visit and see how. Of cause, budget is a concern. Not until rm6-10k.
If i remember it correctly its metallic plus, green box.Which model of Trestor? Normal, semi metallic or blue advantage? Actually Trestor and Bendix from same local manufacturer...
That one is one rung below Blue advantage and is similar to Bendix Metal King. My metal king also makan the disc rotor.....If i remember it correctly its metallic plus, green box.
If brake fluid have gone down and do not have any leaks, means your brake pad/lining have worn down, better just check to see how much left.....I realised that my the braking fluid's level was at LOW, then after my mechanic topped it to FULL my car now brakes consistently. I guess that solves it hehe
Pro RS should be good enough. Is your car firewall so soft, to use brake stopper?Any brand to suggest for steel braided hose? So far I tried PRO-RS consider good. But there is one more brand which is more
expensive, Goodridge...anyone tried and able to compare both of these?
Bendix heard of it before, might try on Kelisa and also the Brake stopper can get anywhere?
Pro-RS used for toyota, the other one is my gf complaining that Kelisa brake pedal have toPro RS should be good enough. Is your car firewall so soft, to use brake stopper?
Steel braided hose will keep the hose from expanding therefore should have higher pedal feel, and better pads for better bite. I drove my colleagues Kelisa before and the brakes I find is pretty good already....Pro-RS used for toyota, the other one is my gf complaining that Kelisa brake pedal have to
press quite deep in only it starts to bite, so wondering to ask the mech to adjust a bit so that
no need to press so deep in, I'm kinda use to it already just that braking wise, still find
that need better pads and braided hose...to improve better braking...
So since dayline mentioned brake stopper helps, so thought maybe can try...
okay then, just maybe braided hose can have higher pedal feel and also is there anyway toSteel braided hose will keep the hose from expanding therefore should have higher pedal feel, and better pads for better bite. I drove my colleagues Kelisa before and the brakes I find is pretty good already....
