Drive a Honda Civic Eg/EK Must Read!
E-Tech
1,115
256
3,183
Johor
Hi bro.. Mine is a Hondata s300 bundled Ecu. Bought brand new from authorised Hondata dealer It is still basically a obd1 ecu brand new equipped with the s300 fitted all by Hondata themselves. So am I affected?
Yes, just repaired one yesterday.... Caps leaks and also Ic17 spoiled. (PO8 with S300J)...
Just have a check inside.... If they have changed all the caps before hondata-ing it then you should be
Ok...
levin818
1,260
321
3,183
Shah Alam
IMO it is not a brand new ECU. It is a used ECU fitted with Hondata. A brand new OBD1 ECU will cost you more than RM5k...
s300 comes with one new cap 220uF 35V, as it is recommended by Hondata to replace it. So i think yours only have one cap replaced. I'm doubt the dealer will change the rest for you as it will incurs addition cost to them.
ryand
47
1,508
hi guys any other components I need to check if ecu cannot turn on fuel pump..
i replace caps. ic17 and ic12
Jun 8, 2012
tgu/Honduras
good morning e-tech
i'm Luis Coello alias luigihn. I have a couple of damaged ECU.
1) p72. worked on the map sensor connected by soldering with a soldering iron to the battery of the car and does not exceed 3000 rpm and check on but you can get the code.
replace all cap and q31 and continues with the problem
2) p28 whit Hondata s300 indicates the code 4
replace all cap and HIC1,HIC2 and nothing
3) p06 works only three pistons does not check
change and QM1 and QM2 and all cap. and nothing
4) p06 converted to p28 the ignition on to check on and does not read any code, fuel pump relay off
pdta.
sorry for my English is not very good I speak Spanish.
thanks for the help
thinnaph
Jul 12, 2012
5
bkk
yes QM3 replaced..
car wont start CEL wont go off
no fuel pump ON
hi e-tech
i've faced the same problem, it is P27 chipped ecu
1. all cap replaced
2. ic17 (ta8903) replaced
3. qm3 (STA413) replaced
4. all trace are OK (no have broken trace cause from Cap leak)
5. cleaned board
note!
- if short J1 (use external rom), the main relay NOT clicked with cell code 6, 8,... and engine couldn't start. (i've already replaced several rom)
- if remove J1, the fuel pump primed like normal, engine could start but got solid cell
appreciated your advise :proud:
E-Tech
1,115
256
3,183
Johor
thinnaph....
remove J1 and let us solve the solid cel first.
have u tried to find out the error code?
btw u using the P27 for what enjin? Sohc?
thinnaph
Jul 12, 2012
5
bkk
thinnaph....
thx for yr fast response.
if remove J1, there is solid (no error code) the CEL won't go off but the main relay was clicked after 2 sec like normal.
i run p27 on D16Y sohc (non-vtec)
i hv run out of idea how to solve this.
Hi there, I baught this APM adj. for Integra
here's the specs for the coil springs:
FRONT 250/50 (around 3 fingers tyre to fender)
[attachmentid=43915]
REAR 250/40 (around 3.5 fingers tyre to fender)
[attachmentid=43916]
currently on 205/40/17.
is the above setup (coil springs) is recommended? i found out when hitting uneven road around 90-100km/h there's a loud "bummmmp" sound at the front. I suspect the coil springs gap on each...
