Drive a Honda Civic Eg/EK Must Read!
E-Tech
1,115
256
3,183
Johor
Hi all...
Hope this scares'' you so that you will take preventive action before it happens to your ECU.
If you drive a civic EG or EK most possible you have a ECU in your car with the code P27, 28, P08, or P30.
I have repaired about 10 honda civic ecu with this type of problem..
This write up is on a ecu P30 which I had to repair for a friend's workshop customer's car... last saturday nite...
Lucky it was detected before any major mishap occured... A capacitor (C27) in the ecu leaked and cause a short burning a hole in the ecu..
Pls see attached picture for clearer info and take action on yours.... TQ and do thank me too.:biggrin:
freeman1314
203
4
When this happends, what are the symptoms in terms of engine running or wiring?(Beside chacking the circuit board)
It's not easy to remove the ecu to check.
E-Tech
1,115
256
3,183
Johor
Freeman....
The trouble is...there maybe no symptom till it is too late..
Most common...check engine cannot off, cannot start and worst case suddenly burning smell in the car- as 1 friend share his experience....
Some symptom can be intermittent...
It is really not difficult to remove the ecu...anyway as I advise, just check. Tell tell sign on the ecu pcb will be brown patches near the capacitors... might be 1 or some....Tq
E-Tech
1,115
256
3,183
Johor
tq for share bro!!!
NP...click lah the "Thanks" box...
Anyway most important is you do something or take action.
Last I heard... P08 cost RM350
P30 cost RM650
Just remember this morning.... ESPECIALLY those with HONDATA should take action!!!
After investing money in the std ecu to upgrade it with hondata S300, if you board burn up....
~RM2500 will be up in smoke.....
The only theory now why the caps leak is.... too many years has gone by...
our climate here also +++. TQ
camp
395
4
Hi all...
Bro, how much it will cost me to replace all this capacitor inclusive labour, fyi i drove yr 99 civic..
E-Tech
1,115
256
3,183
Johor
Camp....
99 civic but if never modify to EG wiring & ecu then maybe still OK...
OBD2a/b less of these big caps....mostly Surface mount chips and aluminium caps...
Anyway....
DIY lah.....- Max RM5-7
If send to TV/Radio shop....
Caps abt Rm0.50--Rm1.00... let's say 7 x Rm1= RM7...
Labour charge... RM50
Total RM60~70 would be the range in i guess...
But if tebabooo (spoilt) then only want to repair...min RM250(half of ecu price)..TQ
camp
395
4
E-tech...
My civic no mod done, still standard...anyway good info, i think my DIY skill in electronic is not that good, scard to spoil the ecu...
E-Tech
1,115
256
3,183
Johor
great stuff. thanks for sharing. too bad u are way to far from me =(
Thanks..
However still need to change... tv/repairman also canlah as long
as they replace with the correct parts...
CAUTION ALL.
All replaced caps must be rate 105c... 85c cannot hor... TQ
E-Tech
1,115
256
3,183
Johor
Guys...
this picture is the ecu that smoked after a customer balik kampung..was a P27
When reach his destination he smelled like something burning..
Finally he traced it to the ecu...
10 cents coin is for your reference of the hole size....TQ
pencalat
805
19
JB
just wishin to get s300 end of this year..... after reading this thread..... use back my vafc lor....
Audi designs almost never fail to awe. The R4 is simply gorgeous, with design cues from the R8 and obviously smaller, it could be the successor to the next generation TT.
Looks like a real hot hatch compared to the current A3, and the A1 could be one too. But the Cabrio design...
