Open Pod or Drop-In Intake Filter
devil_kevin
67
Bros, I'm driving a Honda City 2009 auto tranny. Everything is still stock except changing to drop-in filter. Planning to change to to open pod filter. Is it advisable to do so or should i just stick back to drop-in. What other things I can change?
Timeattacker
416
19
Johor Bahru
m.facebook.com
Hi Bro,
Open-Pod is usually for those Modded Car,but if ur car is NA type,better choosed the Drop-In type and plus ur driving auto tranny u need low-mid end torque(Drop-In Type).As i know drop in is for pickup and open pod is for end power..Plus,Open-Pod,for power on higher revs and is noisy,and drop in - for power on lower revs and is quiet..Somemore,drop-in can Save ur $$$,- lifetime no need to change filter coz is re-useable and washable..
U better make ur choice wise if not .. your $$ will fly away
P/S: Please correct me if i am wrong,just my 2cents..
:driver::burnout:
D7zul
2,697
848
Shah Alam
to get more power, u need this formula
AIR + FUEL + SPARK = POWER
MORE AIR + MORE FUEL + MORE SPARK = MORE POWER..
open pod provides more air than a drop in air filter
so, it's up2u :wink:
Gudluck :burnout:
pwhyze
924
356
1,563
Gudluck :burnout:
True, but too simplistic. Open pod usually makes power at the top end, therefore not suitable for autos in general. Plus, hot air = bad air. Get a CAI kit, more (good) air = Power!
devil_kevin
67
i been told by few ppl the same thing but still ppl changing to open pod for honda city 09 so that's y i'm asking opinion from experts.
ixeo
4,788
3,080
KL, Malaysia
leave it stock standard.. the gains from the open pod alone is negligible. max gains on an NA car is what? 3bhp if you are lucky? you turn off your air con you get 3bhp for free.
D7zul
2,697
848
Shah Alam
horses are not cheap these days..
3 horse is "not cheap" times 3.. hehe
:biggrin:
hamtaro00
279
39
Ipoh
drop in will do
unless city have the paddle shifter [dont remember if they have it or not for your version] and u tend to rev high high. if overall stock, then drop in.
open pod good when u tend to drive more aggressively , rev kau kau =)
throw in aftermarket exhaust manifold and a lighten crank pulley = happy
D7zul
2,697
848
Shah Alam
1 cubic centimeter (cc) of cool air has more oxygen molecule than 1cc of hot air..
bad or good air is depending on the situation u're in..
if u're in hyperthermia, what kind of air would u want? :wink:
---------- Post added at 09:25 AM ---------- 6 hour anti-bump limit - Previous post was at 09:14 AM ----------
and i think auto or manual, it doesn't matter what intake u put..
the type of exhaust is important..
because bigger & more free flowing exhaust will produce more power at high rpm but lesser power at low rpm
from my knowledge la :biggrin:
pwhyze
924
356
1,563
Cold air = good air is what I meant..hehe
Well, exhaust only channels what comes out of the engine, which comes from the intake...so if you have better flowing exhaust but restrictive intake, it wouldn't do you any good.
Autos mostly change gear at mid range rpm, so if your intake makes power at the top end, useless lor....unless kaw2 tekan in final gear la...
mick87
576
112
i suggest throw in aftermarket exhaust manifold and a lighten crank pulley will be good enuf. My first mod on my alza was aftermarket exhaust manifold which i can see significant improvement on pick-up.
Guys, i'm not really understand about this 2 thing, wats different? can make engine more power & save petrol? easy make a engine down?:hmmmm::hmmmm::hmmmm:
