Need help on car windscreen [urgent]
S16
64
508
Guys, I'm posting this behalf of my friend who owns a iswara. The story, he bought a water/rain strain remover (liquid form) and applied it. After applying it to the windscreen, a white/hazed layer formed. Even after few trials washing the windscreen with glass cleaner and few other liquids, the problem still there. So guys, any of you here have faced this kind of problem? Is there any method to brighten back the windscreen? Hope you guys can help us... Thanks a lot in advance...
eohl79
293
164
543
Bro S16 sorry to hear what happened to your friends Iswara windscreen. First of all the, let me share with what I think might be the cause of the problem. The water/stain remover in liquid form is most probably acid based and quite corrosive (very low pH value). The problem with using those acid based water/stain remover is it works well for glass surface that needs to be entirely flat with no scratch marks, pits, etc. So usually it is only safe for side windows and some rear windscreens (no wipers and glass dependent). Running your wipers on the front windscreen will create micro scratches (especially when windscreen is dirty) and gets deeper over time. Those scratches is usually not visible unless inspected properly under bright light. Even sand, dirt, stone, etc hitting your front windscreen over time would create scratches, pits all over the surface. When those acid based products gets into those scratches/crevices it may get trapped in the crevices and etch the glass thus causing the haze. Also those acid based products needs to be washed off immediately and properly after use - better neutralized. Besides the product, most modern cars have laminated glass for the front windscreen which is softer (probably easier to be etched by the acid) than tempered glass (side windows and some rear windscreens). That's why I stay away from those acid based water mark/stain removers.
A better and safer approach would be to try vinegar first which is a light acid to remove those water mark/stains. If it does not work, the safer method would be to use compound/abrasives meant for removing the water mark/stains. I posted an article on removing the watermark safely before on ZTH detailing forum. I've already tried it on a few cars and front windscreen too without any problems. Here is the link:
http://www.zerotohundred.com/newforums/car-detailing-forums/396809-safe-and-effective-waatermark-removal-on-glass.html
That said, I am afraid your friend's car windscreen would need to be polished off using special glass compound/abrasives (like Cerium oxide) and a rotart machine polisher with the right glass polishing pads (felt) in order to restore back the clarity. If the car windscreen isn't too expensive, get it replaced.
My 2 cents...
---------- Post added at 10:13 AM ---------- 6 hour anti-bump limit - Previous post was at 10:11 AM ----------
Bro S16, you can try CarPro CeriGlass kit which you can purchase from Ultimateshine website to see if you can remove the hazing. Not too expensive but no guarantees :)
S16
64
508
Thanks a lot mr.eohl79, I fully agree with your explanation together with the facts. Yes, he used it for side and rear mirrors too, the water strain removed and the glass look pretty good and clean. I will follow the methods as u said and update you. Again, thanks a lot friend... :)
DanzEterna, i tried but no improvement... Thanks for your suggestion bro... :)
g88
3,081
54
5,148
your friend must be using TomCats bought from Carrefour.
S16
64
508
Nope, he bought it from Jusco... :D
---------- Post added at 09:03 AM ---------- 6 hour anti-bump limit - Previous post was at 09:01 AM ----------
What brand your friend used? Better warn the other forummers here.
Sure Mr.Wegatech, will let u know later. :)
Supra_Fanatics
20,673
3,998
Wah....how come will have swirl marks on windscreen? :stoned:
Ermm...change windscreen?
S16
64
508
what brand that already use..better info..so that frenz can avoid from using it....
sure bro... haven't give a visit to my friend's place... :)
---------- Post added at 02:37 PM ---------- 6 hour anti-bump limit - Previous post was at 02:23 PM ----------
dear friends.. how about swirl marks on windscreen. any chance to remove it? :banghead:
you can try to use CarPro CeriGlass as advised by eohl179... CarPro CeriGlass removes the small scratches on the windscreen... But you need to use it with rotary device... Try to refer this link, quite helpful, http://www.autopia.org/forum/product-reviews/138733-review-carpro-ceriglass.html
I myself having problem with my windscreen, collecting some money to give a try on CarPro CeriGlass...
spoon civic
403
36
terengganu
carpro same like polishing car body with polishing machine?
peeche
395
165
Sin City, MY
don't know how it happens.
i left abroad for 3 months.
left my car at parent in law house.
when i asked everybody say don't know.
:banghead::banghead::banghead:
---------- Post added at 05:35 PM ---------- 6 hour anti-bump limit - Previous post was at 05:32 PM ----------
or anybody esle can do it for me.? i pay some laa.. hehe :wavey:
S16
64
508
try ask around... i have asked few shop around my place, all suggesting a new windscreen... that's why plan to do it myself together with my friend...
---------- Post added at 07:19 PM ---------- 6 hour anti-bump limit - Previous post was at 07:12 PM ----------
yeap... but I believe there is a proper method to be followed, not by just playing around with the rotary device... you will need to choose the right polishing pad too... I'm still doing my read up on it...
spoon civic
403
36
terengganu
Why don't go to Dr.Cermin which is specialist for winscreen repair?
This incident happens to me yesterday evening.
my car having problem starting up since the day before yesterday.
i've change to a new battery, and it works well until yesterday, the car broke down in front of traffic light around jalan universiti.
after waited there for 30 minutes, got 2 indian guy claimed themself is a foreman, and come to offer some help.
they push my car beside the road so not to block the traffic.
i just ask them to help me jump start my car and i'll pay...
