help reading out spark plug condition
upontheriversky
275
82
hi,
i recently serviced my car and asked the mech to take out the spark plug to see the condition of it,
below is the pic:
it looks like its in healthy condition judging by the light gray deposit but the cracks look like i have been experiencing detonation
any help?
crazykatak
776
48
Subang Jaya
hmm..does not look very healthy..
a healthy one should be brownish at the ceramic and the electrode,which suggest good AFR condition.
btw, when was the last plug change ?
Dayline668
1,810
492
1,683
looks like running a bit lean.. normal lo..
upontheriversky
275
82
the plug has been in for 15k, its an iridium
i would say the plug is burning too hot......
you need a colder plug.........
any sifu wanna comment ?
thx for that. ive been thinking of using colder plug too
i have 2mm oversized piston fitted in, exhaust mod, oem airbox and filter and CAI. is the mod enough to cause lean af?
is leaning of af is what causes the plug to burn too hot?
12savefuel
195
75
hi,
below is the pic:
any help?
I would need a very close up picture of the plug in order to tell. use a digital camera in macro mode and take the picture of the centre electrode and porcelain. Like this picture here and the same angle as well.
From the picture I can't see any cracks. If there are cracks in the porcelain its definitely running too hot. What car is it in and what plug code is that. From the picture it looks like the car is running abit lean. Can you hear actual detonation on the car? Looking at this plug I would go one step colder and see how it goes. If it looks ok then I would stop there if not I would even try 2 steps colder depending on the look of the plug, driving style, type of car/engine and mods.
Wilson13B
296
30
The plugs show that your engine are running lean ...
I been experience with Plug Condition Vs AFR for countless of time .... this is just fairly lean and should not causing any detonation but will certainly do harm to the combustion chamber/piston dome .... if you have a AFPR,adjust to increase the fuel pressure and try it out ~
g88
3,081
54
5,148
Too lean (diy) , not enough burning...you need richer AF mixture. FC would be good but power might optimum
Does anyone here got the wiring diagram for the Pivot ACS-X device? Would like to try and install the gadget myself but can't seem to find the wiring diagram on the net. :sad_smile: Any sifu can help?
