Incorrect Speedometer Readings
turbolover
1,185
112
Hi, I basically bought over a proton with a VR4 engine. The previous owner couple the engine with the original putra speedometer however after driving for awhile i noticed the readings are not correct. It's registering faster than what it should. Probably about 20km faster. Any ideas of how to solve this? The current rim size is 16 and IMO that should not affect till the readings are off by 20km/h.:hmmmm:
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
...or the speed sensor not compatible? i.e. VR4 reading is different than a putra?
turbolover
1,185
112
Hmmm putra's meter reads till 260. Speed sensor? Doesn't the older mitsu use cable?
Veloc
3,234
991
Sabah
I have this reason and revrntly solved it... My speedo was showing 20km/h above the real speed. After a few weeks, the speedo totally malfunction. Sent to shop the mech said my speedo meter cable broke. So I guess maybe previously, it was loose already or almost breaking. That's why the reading sotz... Din't know if your problem is the same...
mitsu4G
229
8
Johor Bahru
guys..jez wana ask, how bout if the RPM meter jumping up n down..n sometimes ok,sometimes not..wut probably the cause of this problem??
turbolover
1,185
112
In my case I don't know about the history of the meter. Not sure whether the meter was accurate before that.
dennisdreams
333
21
Install a RSM~ ^^ then key in your wheel's diameter and it will calculate the right speed for you. If wan to get more accurate speed reading, add on the G-sensors~ ^^ can even get 0-100KMH and 0-400m sprint data~ ^^
turbolover
1,185
112
Yes, his would be another option right? Hmmm will consider the cost involved. Thanks.
93na
597
20
car acceleration seems fine..not jerking at all, only the rpm needle..
i had the same problem when low rev ok. when revving the car the meter jumps to 8k and back to 3k then jump again but car no jerk or anything.. found out that the coil sensor loose.. now ok already.. try checking all the sensor...
EGNINE
513
65
3,028
happen to me before but it was slower 20kmh from actual speed, change speedometer cable then problem solve...
Hi guys,
i had a bilstein absorber in my e46 which i think is wearing off already.
i've heard about places where i can rebuilt/refurbish absorbers...however usually adjustables can only be done. any ideas?
