Golf GTi check engine light
feezdya
1,814
223
Pee Jay
www.takaful-ikhlas.com.my
dear sifu, my check engine light just pop up ...and now jerking when high rev...spark plug problem or o2 sensor etc? anyone experiance on that? mine clocked 92k km...Mk5 GTI
keisukosan
316
7
beta take to check it asap before it damage ur engine or other compartments~
R32
Mar 26, 2012
28
5
503
misfire !! i suspect ... either spark plug or coil packs ... i have the diag tool if u want me to scan for u ?
waynezyu
From Facebook
Mar 26, 2012
46
508
www.facebook.com
I had the same prob before is inner coil
mazranz
Sepang Circuit Staff
284
10
3,018
Pee Jay
mazranz.smugmug.com
What year is your car? I heard there are some problems with 08-09 Audi/VW 2.0 TFSI engines, which is related to the camshaft adjuster.
My audi had the problem, just out of workshop for 1 month. Same problems you are complaining about.
Luckily under warranty, so in total they changed the camshaft adjuster, cam shaft, intake manifold. Lots of work!
better get yours checked... it is actually a service recall by audi.
hi all sifus,
i had changed my fuel pump,injector,metal gasket,racing clutch,installed boost controller...
boosting at 1.3 to 1.4 bar,somehow i felt not satisfied with the 'force'....
wat else i need to modd in order to get another 50 to 80hp?? a bigger turbine td005?install SAFC?e manage??(is it make a lot difference if install a SAFC??)thanks in advance
