169.6 hp campro cps
ae92r
222
I think....there are turbo on it.....coz the top hp comes at the middle of rpm which is about 5700 rpm.....vtec n mivec came little bit late maybe after 7500 rpm.....just my thought.....
But if its real....this is a breakthrough......
TopRpm
295
46
if its N/A Campro CPS..then..walauweiiiii!!!! :adore::adore:
TimLang
86
6
1,508
I just saw in a Local Magazine claim Campro 1.6 SuperCharger produce 160++HP (on wheels) from powerzone tuner. I guess it is not impossible if Campro CPS NA can also produce 160++ (on wheels).
TopRpm
295
46
pls someone list down what mods n toyol inside dat engine...really curious to know, hehe:hmmmm:
satria_neo
Aug 1, 2011
47
9
508
Singapore
Nope its definitely NA cause the torque/HP ratio shows its NA engine. Turbo will have much higher torque.
---------- Post added at 10:41 AM ---------- 6 hour anti-bump limit - Previous post was at 10:38 AM ----------
Actually its quite possible. Cause Campro's redline is quite low. IF it can be increased to ~8.5K then it should be around 200HP already.
Of course, this assumes the internals are balanced and lightened, valve train is modified to support (stiffer springs, different cams) etc....
azzul86
9
nope this is n/a and cps activate at 4000 rpm
if turbo, it's produce more curve toq..
Really interesting what have inside the engine....
sure want this not TOYOL from malaysian....
---------- Post added at 12:42 PM ---------- 6 hour anti-bump limit - Previous post was at 12:41 PM ----------
BK Motorsport????
where is it??
kambing69
216
33
Where is BK motorsport?
Owh BTW my Neo R3 cuts its RPM at 8k so i think max RPM is about 8.5~9k maybe~
And this CPS is indeed N/A not super or turbo for sure
satria_neo
Aug 1, 2011
47
9
508
Singapore
Btw, another possibility is that its supercharged using a roots or twinscrew blower. Cause only such blowers can given a linear increase in power/torque which makes it behave like a bigger CC NA engine.
fquantum
107
If it is turbo or supercharge the dyno sure
will show its boost rite...
I think this is n/a....
benjoooe
From Facebook
Mar 13, 2011
4
www.facebook.com
this is N/A CPS.. :D .. now the owner is going to prepare for 180HP on wheel for campro.. stay tuned.. :D
---------- Post added at 12:37 AM ---------- 6 hour anti-bump limit - Previous post was at 12:31 AM ----------
the engine bay..
