Car Voltage Reading
GSR06
455
17
Hi Guys,
I have one question that I would like all Sifus to give their valuable inputs. I currently have this problem which I don't have a clue on what the issue is.
Here it goes....
1) What should be the voltage reading at idling?
2) What should be the voltage reading when you switch on your air-con + head lamps?
3) Will the voltage drop when the air compressor kicks in?
My voltage is ~12+ v before I start my engine. After I start my engine, the voltage will increase to ~13 plus to ~14v (Remember that this is at idling). When I switch on my air con + head lamps, the voltage will drop to ~13v only. When air compressor kicks in, the voltage drops to ~12 plus v and sometimes, it dips below 12v at idling. When I press on the accelerator, the voltage increases again to ~13.9v (with air con + head lamps ON).
I actually changed a new altenator (APM, 75A) but the symptoms persist.
Is the above conditions normal during idling?
what was your rpm during all that a/c on (compressor cut in)???
if below than 750rpm maybe u might need to increase a bit the rpm during load....
amrancharger
779
96
same symptom as my voltage reading.
but when the voltage drop there is no significant effect or the idle suddenly become high or low.everything seems to be normal.
but this really worries me, cuz planning a long journey of balik kampung. :driver:
dun wan me stranded in the middle of nowhere wif my family.
or shud i try removing the negative terminal at the battery while idle to check?
well i m scared if i do dat i might do more harm...huhuhu!
yeehau86
Feb 10, 2007
2,856
2,425
Hi Guys,
Here it goes....
My case:
1. Above 13V but below 14V
2. Drops a bit but never below 12V for a healthy situation
3. Yes, but just slightly
There was once my situation same as yours in my previous car where I have to press on the accelerator and the volt meter reading goes back up, but once on idle status, the voltage drops back to below 12V and my dashboard meters, digital clock, radio and aircond light starts to fade and my car barely dying off that I have to keep on revving the car on idle status infront of the traffic light. My case was due to alternator issue, once replaced this was solved, not sure about yours. Anything below 12V for me shows a bad sign of voltage.
GSR06
455
17
I am just afraid it might affect other parts later on and I just changed my alternator. BTW, do you know how much a new APM 75A altenator costs in the market?
does it effect your car?
---------- Post added at 07:31 PM ---------- 6 hour anti-bump limit - Previous post was at 07:29 PM ----------
My RPM hit above 1k during a/c on. I am monitoring now as the voltage will drop below 13v once compressor kicks in.
---------- Post added at 07:34 PM ---------- 6 hour anti-bump limit - Previous post was at 07:31 PM ----------
Today, my voltage stays around 13.9~14.0v at idling and when I switch on the air con + head lamps, the voltage drops below 13v but not below 12v. Is this considered as an altenator problem as it is so called 'brand new'? Do you know if there is a device to boost the voltage or making the voltage more consistent?
My case:
---------- Post added at 07:39 PM ---------- 6 hour anti-bump limit - Previous post was at 07:34 PM ----------
Did you see the battery icon when you put on the ignition? If you don't see, then your altenator might have problem as it's the signal for altenator.
You can check your battery health at the batter shop. Voltage ~12v plus before you start the engine indicates a healthy battery. When you start your engine, the voltage should increase until 13v or 14v, depending on your altenator condition. Anything above 16v means overcharging and it is dangerous though. If your battery expanded physically, it means over charging.
My car's condition is different la...hard to describe. Would it affect the voltage if my air compressor is faulty?
amrancharger
779
96
i guess i haf to bring my car to my mech for checking.
the voltage before start is 12 and sometimes below 12volt... :bawling:
bera
822
229
my voltage reading
12.4 before engine start
14.4 idle
14.0 when lights on or other electrical load then back to 14.4 after a while
13.0 lights + aircond (which i rarely use)
IMHO it depend on car to car...for example: stock car vs car had those high end ICE...
1 point worth mentioning to you is...before this my car have a few cables of grounding wire only...and the voltage fluctuates ranging from 0.5v to 1v...i notice after i install a set of grounding cables (ayam brand) the voltage is more stable...now rarely fluctuates..and if it does...it just 0.5v max...
as for your other concern about the alternator and such...a higher rating alternator doesnt directly solve your wattage issues...it just make charging more efficient...as all the charge generated are stored in the battery...
there is a lot of device in the market claim to increase/stabilize voltage output...pivot, hot inazama to name a few and some even diy their own stuff...just tepuk poket tanya wallet :driver:
GSR06
455
17
Did you observe the your dashboard lights going dim for a while when you turn on your air con? I am currently using the Pivot grounding (blue unit) but it still doesn't help much. In addition, your 13.0 is during idling or car running?
my voltage reading
14.4 idle
---------- Post added at 09:11 PM ---------- 6 hour anti-bump limit - Previous post was at 09:11 PM ----------
Yes, better check now before it becomes serious... I am just worried about my ECU...
bera
822
229
yeah...but only dim a little...in my case ignorable...since the wattage reading from volt meter (measured using imitation pivot vcapa) only drop a bit...13v is when running...if idle and compressor kick in drop down to 12.5 plus minus...after a while will bounce back to 13...off compressor then reading climb back to 14v...never fall below 12v regardless of electrical load (radio + aircond compressor + radiator fan + lights)...
if you worry about ecu...then make sure the ecu fius (use proper rating as recommended)in good condition...so that if there any surge of current will cut the power to the ecu...
teo1957
280
164
I think if yours is an Evo you need to have either your ICV or your AFM sensor checked.
Once I had the same problem and I replaced the exact same thing first: alternator, thinking that it is an electrical supply problem. I found out that alternator is not the CAUSE, it's the EFFECT of irregular low RPM.
Irregular low RPM is caused by either faulty ICV or AFM sensor. Can go to workshop that have spares, swap and try. Or you can DIY clean using electronic contact cleaner: 30 minute job.
jimmyae101
1,167
112
medan indonesia
normal if fan on during air on...rpm below 800 to 950 for different...if ur car rpm below 500 of coz underpower need acc a bit petrol...or serivce air filter,throolte body check spark plug...noramlly how much voltage on battery not really effect car performance,rpm important..idle how much and free idle how much...make sure rpm timing correct anything ok
GSR06
455
17
Almost same as my case... but my voltage fluctuates a lot. When I turn on the head lamps, the condition gets worst. Are you using normal head lamp?
---------- Post added at 07:51 PM ---------- 6 hour anti-bump limit - Previous post was at 07:49 PM ----------
Bro, not an Evo la. My RPM looks ok and I guess my AFM is ok as well but I can further check later...
clanzkiller
1,394
27
1,648
As far as i know, Voltage reading only indicate the weakness of the battery, operation of an alternator, and other electrical supply. It doesn't really affect performance, but some claimed that good earth grounding increase performance.
Scenario is baseless, alot of things can cause voltage to drop or fluctuated.
Related
1. Weak/Old battery
2. Alternator dieing soon
3. Bad earth grouding
4. Short-circuit
5. Audio system
6. Usage of electrical supply
Unrelated
1. Low RPM
2. When starting where starter required lot of energy to light the ignition.
This is what i can think of at the moment :)
GSR06
455
17
Scenario is baseless but if you don't share, it is also meaningless :biggrin:
Bro, could you share yours or not? If there is a problem, we need to troubleshoot lor. Anything can go wrong but we need to find out exactly what goes wrong but I know it will take time...
As far as i know, RPM reading only indicate the weakness of the battery, operation of an alternator, and other electrical supply. It doesn't really affect performance, but some claimed that good earth grounding increase performance.
Related
1. Weak/Old battery
4. Short-circuit
5. Audio system
Unrelated
1. Low RPM
Went to ENEOS today.
The reason I went there is to purchase Tufoil after reading about so many good point about the tufoil.
Searching around in ENEOS about 10 min for the Tufoil and finally manage to find.
Beside Tufoil, there are so many engine treatment and 1 of them is X1R. The TV ad next to the X1R engine treatment keep on playing the ad for X1R, I wonder whether it really can perform as what they claim?
How about compared with Tufoil? Which 1 is better?
I end up walk out ENEOS...
