help!! my 20v idling problem!!
D7zul
2,697
848
Shah Alam
better find mechanic that's familiar with ur car engine model..
diff model, diff engine, diff problem..
experience mechanic solve problem more efficiently..
:biggrin:
me2kimi
717
276
1,563
Puchong
Sometimes there is a problem that we face/thought is not directly from the root. Yes, experience mechanic solve problem efficiency coz he may found this problem earlier.
For a new foreman, it take a while and changing parts after parts then he can found the culprit.
Almost similar situation with my field job.
alex_khoo
163
:biggrin:
bro zul...my car send to 20v expert in kepong and puchong utama but they cant solve my car idling!!change tis change tat!!! pening:banghead:
D7zul
2,697
848
Shah Alam
the easiest way to solve it is to get a half cut.. & change d whole thing :biggrin:
but it involve lots of $$$..
Gudluck :burnout:
me2kimi
717
276
1,563
Puchong
yup, agree with dzul. Silvertop always like that. Idling is common problem. Better get BTop wiring. Kegani also advice me this step when I ask about idling problem
alex_khoo
163
now full set bt wiring how much include labour?
levin818
1,260
321
3,183
Shah Alam
Idling problem in Silvertop:
- Clean ISCV
- Clean 4-throttle (must strip into piece)
- Check all vacuum leak
It will only cost you less than RM300 bucks and one day down time.
If swap to BT ECU and wiring just because you wanted to get rid of idling problem, your pay off is ~RM1500 and ~2days down time.
RM300 or RM1500, its your choice :biggrin:
---------- Post added at 05:50 PM ---------- 6 hour anti-bump limit - Previous post was at 05:46 PM ----------
Alex, according to the mech, you refuse to clean your 4-throttle because you don't want to leave your car there for a day or 2. If this is the case, you will never solve your idling problem, no matter which workshop you go. Please discuss with the mech and find out the solution.
kelvinyong83kh
Nov 20, 2010
39
508
- Clean ISCV
bro Levin !!!
where to recommended place/shop to service those item ?
coz i go no ideal to have contact who good in check n service BT ?
thanks.............
hon_cs
251
43
3,028
Ipoh
actually what levin818 said is correct. bear in mind if after you changed wiring and the problem still there. what you need to do next?
antue
49
'cucuk' diagnosis...
mine after diagnos appear vacum sensor peoblem..
just my 2 cents
nicholas1007
510
After i changed the walbro fuel pump. So fast my fuel gone down. Is this normal? Izzt recommend to put in a piggybak after installed walbro?
lkeong88
394
121
Cheras
After you install the car feels better in acceleration? Is it loud? I heard its recommended to have FPR or piggyback
I've seen on the road an aftermarket suspension for AE111 and AE101. I am talking about the lower control arms anybody here knows what brand is it?
Thanks.
