First Impression: Saga FLX CVT at the Test Track
Tom
TIMETOATTACK
Jul 6, 2000
5,562
3,229
In the looks department, the New FLX remains identical to the recently launched FL, which by itself, is a vast improvement over the first gen Saga. The 2 important difference lies in the CVT transmission and an improved engine breathing through the IAFM intake.
Photos and Report by Alvin Lee
Facts About CVT in the Saga FLX
- Much smoother operation compared to the Automatic
- Up to 10% more fuel efficient compared to the Automatic
- CVT Made by Belgian Punch Powertrain. supplies to MINI, Volvo, Kia
- Dedicated CVT oil cooler for heavy-duty robustness
- Service life of 200,000 kms according to Proton
- 25% less parts compared to conventional 4-speed Automatic
- CVT will now replace the automatic Sagas
The CVT
The Saga, being Proton's blue eyed boy, is intended for the masses and will be used as a workhorse, so rather than simply fitting it with CVT and be done with it, they went the extra mile to add a dedicated oil cooler that sits just ahead of the radiator, dramatically increasing the CVT's efficiency.
LED Taillights
Heat significantly dictate the CVT's performance and with the addition of the oil cooler, fluid temperatures remain at a constant 70°C under most scenarios which is perfect for keeping the transmission "chilled" and shall guarantee smoothness throughout long distance driving, hard acceleration or hill climbing.
Pretty Much the Same + New IAFM and Engine Tune
Speeding through the "Semi" high speed test track
Performance
To make the most out of 94bhp, the CVT transmission compliments the engine with less load and further increases fuel economy under most conditions. The drive around the Proton Test Track reveals that the Saga FLX does have some punch in mid-range and thins out at about 5000rpm as the 1.3 IAFM 16V starts to grumble.
Crunch the figures above
Fuel Efficiency
In Proton's own tests, the CVT Saga was able to manage 5.7litres for 100km at a steady 90km/h. Using the direct, unadulterated 5-speed manual as a benchmark at 6litre per 100km, the difference here is about 0.3litre between the CVT and the Manual for 100km.
It's got the modern Playstation touch
New FL helps make the Saga look more proportionate
The Drive
It's not everyday you get to drive on an oval proving ground, and Proton actually have one in their backyard. Being utilized for research purposes, the facility, dubbed the Proton Test Track allows engineers to put their creations to the ultimate test. Constant high-speed runs on the oval, high speed maneuvers, pebble surface for noise, a braking and such.
The Proton playground
Check, check and check.
The gatekeeper
The Bank.
Top Secret development going on here
We were provided with 2 variations. The 4-Speed Auto and the CVT. With the automatic, the engine is seen to rev at about 3000rpm at 100km/h and the CVT at about 2500rpm. It is clear how much less, the precious energy is lost with the CVT's wet clutch system compared the ancient torque converter of an automatic transmission. Translating to an increase in fuel efficiency.
Thundercat helments
Just in case you get lost in research
We'll be seeing more CVT integration in current and upcoming Proton models, and the Saga FLX looking like it's a winner at the moment, could well be considered as a great, budget daily driving 4-door.
BE5RSK
343
125
Besaout
94hp in NA 1.3 liter is amazing... :adore:
Kudos to Proton. Keep up the good work :top:
continental_drifter
259
15
3,018
another one stupid gearbox made by proton after what they did to Savvy =)..
Because it happens to me..the car itself is good, but sigh...GEARBOX!...
i wolud recommend u guys to take the manual version of saga FL rather thn this CVT crap..
VectorX2
268
45
the exhaust manifold cover and the position of the O2 sensor seems a little different....
Btw, the manual transmission for FLX is different from BLM and FL, instead of the one from Aichi Kikai, now they source it from Getrag
VectorX2
268
45
The ABS do come handy, i am driving a BLM, especially during puasa time. i do alot of emergency braking and skidding hahaha... escaped accident twice without ABS, with ABS, i will be abit more confident driving...
chaics
31
2
1,508
how many bhp is the 1.6L saga?? from proton edar website, its written 82.. lower than the standard 1.3L? true??
Hey guys, my ride is a wira 4g15...im currently using fully synthetic oil, it consumes around half a littre during my 7500km oil change...my engine has been consuming some engine oil at this rate although it only has 70k on clock after a fully engine rubluid..
guys, is it normal for a 4g15 to consume engine oil? im currrently u sing 5w30 bardalh fully synthetic oil...issit normal for this engine to consume more oil after i trevel high way?
guys, i need ut opinion...thanx...
