Evo 8 MR, Front Suspension Knocking Sound!!!
[email protected]
97
16
1,508
Hi All ZTHians,
I've just recently started to notice a knocking sound coming from the front left suspension in my Evo 8 MR. It only happens when im going over bumps quickly, when i go over speed bumps slowly there is no knocking. The knocking was very minor at first but i can tell it is starting to get worse. I have had a look at the suspension mounts and the suspension itself but there seems to be no signs of any damage. Could it be the bushes that need replacing, would this cause the knocking sound? and is there any way i can check for this.
Thanks All, any help appreciated.
[email protected]
97
16
1,508
could it be the engine mounting? does your car vibrate during idling?
No more than usual, the engine always been quite "burbly" when idling... Any other signs that it could be the engine mount?
[email protected]
97
16
1,508
perhaps your absorber has soften up...
By this do you mean that when i go over bumps the absorber is being fully compressed and the knocking is it hitting its travel limit?
or could be your lower arm bushing..pls check..
:adore:
alwhitesat
760
30
the rod collar might been leaking air bro....so, there's no air to be compressed in the absorber, it is an early sign of leakage, over time, oil leaks out too...it was my experience,i changed both lower arms and the prob still persist, changed to new sets of coilover and the problem gone!!
[email protected]
97
16
1,508
Alright thanks man, it seems like that could be the issue then, I did notice what looked like a bit oil on the absorber but its quite dirty under there so it might not be... the only other thing i can think is that something around the suspension underneath has broken, i did hit a bump quite hard in the dark and kinda took off and landed quite hard so i think that could be what caused it. Anyway the car is in the shop now so fingers crossed its not an expensive fix. :adore:
infinity.melvin
SlowPoke
1,600
153
kuala lumpur
i use to face this issue couple of weeks back. changed the absorber mounting works good for me.
the absorber mounting KO already, thats y got movement which makes the knocking sound. absorber mounting should not move at all (the inner part and the outer metal part)
i end up changing whole adjustable set for my car only realize got absorber mounting KO already..
Hi,
I bought and installed a new SK POWER VS three weeks ago. Since then I had to go back to the shop two times to change the mulfunctioning VS.
All three VS (with the same brand) had it LED stop flashing after a couple of days. I asked the guy who installed it about the problem and he said that although the LED is not flashing the device still work. Is it true? Does anybody else having the same problem?
Is there any other brands which is better than SK POWER? What price?
Thanks.
