FAQ Lexus IS250
AE111_SEG
1,024
180
Putra Heights
Guys
I think it will be a good idea to start a thread for future members.
I get the ball rolling.
UK model standard factory tuned to run Ron 91
Malaysia model standard factory tuned to run Ron 95.
Japan model standard factory tuned to run Ron 100
Is there a difference in the performance between the 3 models?.
We have all three model sold in Malaysia......:proud:
lathen
121
2
Johor Bahru
Im driving a UK spec is250, performance wise no problem to overtake 523 on highway
---------- Post added at 09:20 PM ---------- 6 hour anti-bump limit - Previous post was at 09:18 PM ----------
Anyone able to get GPS DVD from malaysia spec ?
Greytezza
1,130
68
1,648
Truly Asia
I think the better comparsion would be the Beemer 325I in terms of size and weight to power ratio.
lckia
77
6
508
Guys
IIANM, Japan torque is 260Nm against UK and Malaysia of 252Nm.
Speed limit:
UK & Malaysia - none
Japan - 180km/h
Veloc
3,234
991
Sabah
Speed limit:
Japan - 180km/h
Haha... You mean no limit on speedometer and ECU bro?
cykosis
Hi guys, anyone got the gps maps for Malaysia for UK spec Lexus. Also anyone can help me switch from miles to km on the odo?
Thanks for reply
Perry Yip
68
Klang
Thanks for reply
Yeaps, i need the dvd map too, with info how to switch from miles to km on the odometer. 0122383871, thx.
lathen
121
2
Johor Bahru
if u know anyone from Lexus Malaysia, or whoever driving CT200h that come with GPS, or whoever driving local specs Lexus that come with GPS, then can borrow the disc from them, and burn a copy to try. I been looking for it since last year, If really happen to get a copy of the disc, pls pls share wif us, :biggrin::biggrin:
xfuture
129
I've been running RON95 on a Japan Spec for 3 months, without any problem.
Anyone can tell what kind of maintenance should be doing for my case?
ed78
353
29
for me,
i'm running HKS fully syn - so change black oil every 10K - but i don't reach that mileage. so i change oil every 5 months (6 months should be limit)
major service at 60K km. - so just make sure you follow the recomended intervals.
green
326
25
3,028
kl
i believe toyota/lexus will tune the car differently depending on the fuel being used in diff regions.
meaning they will probably have more fuel maps in the ECU itself to accomodate the decrease in RON
like ed said, japan spec can run on ron95 with no issues. uk spec can run on ron 91 minimum. hence all is250 in msia should be able to run on ron95 with no issues.
this is good info.
Dear bros, saw an Avanza using K3-VET engine, is it a direct swap?
Anyone swap before?
What about the gearbox, long shaft and axle?
