TYRE GUARDIAN
Tyre Guardian is a concentrated liquid gel which is easily installed though the valve after the removal of the valve core. After the installation, the product is spread completely throughout the inside of the tyre (by rotational forces) sealing all porosity leaks (rubber is a naturally porous material), bead and rim leaks. The coating of the product provides a barrier which maintains your tyre pressure and a complete air tight container. Thus, maintaining the optimum pressure for the full legal life of the tyre.
In the event of a puncture, the pressurized air inside trying to escape will immediately draw the Tyre Guardian to the source of the leak and seal the hole. Regardless if the puncturing object is removed or not, the Tyre Guardian will seal all porous holes and leaks. Tyre Guardian’s sealing function is permanent and the tyre does not need to be removed and repaired. This eliminates the need for the driver to make immediate stops to check on the tyre.
After installation the Tyre Guardian will lie dormant inside the tyre until the need for it to work arises
Tyre Guardian is made from a special formula containing latex and is not harmful to the environment when the tyre is disposed. Once installed, Tyre Guardian is 'on guard' and seals any punctures as they occur, for up to five years (unless the tube is physically damaged).
BENEFITS
* Safer driving conditions
* Prevent tyre blow outs
* Maintain better tyre pressure
* Improve fuel consumption by up to 10%
* Reduce tyre temperature
* Helps control under-inflation (the number one tyre killer)
* Increased personal and occupant safety
* Prolong tyre life
TYRE GUARDIAN will (provided no casing or dangerous structural damage occurs) permanently seal punctures caused by objects up to 6mm in diameter (tubeless tyres).The seal will provide protection for the legal life of the tyre.TYRE GUARDIAN will leave an indication mark to show where a puncture has occured.
WARRANTY
Warranty is for 1-year from the date of application. An extension of the protection plan for the 2nd year is available for an affordable fee.
Prevention is better than cure. With the Tyre Guardian not only do you save time and money, you can rest assured that it is working at all times to protect you and your occupants from imminent danger and inconvenience.
TYRE GUARDIAN does not prevent leaks or punctures caused by damage to tyre sidewalls.
VIDEO
http://www.youtube.com/watch?v=Yjm23kulugs
Package includes: Tyre Guardian+Installation.
Prices: Pls PM me and i'll quote u.
Dealing method: meet up for installation.
Location of seller: Selangor / Wilayah Persekutuan
Contact method/details: PM me.
Age of item: New.
BENEFITS
* Prolong tyre life
WARRANTY
VIDEO
Age of item: New.
