[WTS]RAYS ENGINEERING CE-28N 15"x6.5jj 39offset PCD100
Hi bros,
I have a few questions here.
Last week i re-installed my Vacuum Gauge from my old car (Iswara 1.3) to my Vios '05.
Due to the Vacuum hose is too big in diameter (8mm) for the T-joint (to the sensor), I changed the hose to a small diameter (7mm).
Question is:
1.) will it affect the engine if i change the hose diameter to a smaller size?
2.) the mechanic said that Vios is not advisable to intall a Vacuum Gauge as it need sufficient air. Is this true? I have not come...
