- Joined
- Oct 15, 2007
- Messages
- 56
- Points
- 1,506
HWL Adjustable Suspension
Price: RM 1700.00 for Myvi (Cash & Carry)
other model also available, PM and ask
Warranty 1 year
Item is serviceable
Note:
Deposit of RM 1000.00 is required for material ordering
TiTAN is a Shock-Absorbers Specialist which provide solutions in customized suspension which are tuned according to our customers’ needs and driving preferences. With years of highly-stressed racing experiences, Titan has produced suspension performance that are hardly equaled by its competitors. Titan’s Inverted Mono-Tube utilizes a large piston area which produce instantaneous response to the slightest suspension movements. It’s tube strength is tested to up to 1,000PSI gas pressured stability. It is impossible to have dead-spots in a Titan.
Our Suspension Basic specifications are: -
Inverted
Mono Tubed
Tube strength – gas pressure tested up to 1000 psi stability
Around 80% oil filled – fully synthetic
Oil type varies depending on requirements
Around 20% gas – high pressurized also known as “high charge”
Gas type “Nitrogen” – vacuum before insertion
Gas pressure varies between 200 psi to 500 psi
Gas pressure specification differs from person to person or case to case, depends on requirements
Valving – large surface area – non disclosure
Bush – Teflon – double or more – non disclosure
Seals – double or more – non disclosure
Coil spring rates – LINEAR (always) between 2.5 kg/mm to 5kg/mm at around 0.5 kg/mm intervals
Coil spring rates – higher figures are available
2 years warranty
Please feel free to browse the official web site for more information
TiTAN - Custom Built Performance Shock Absorber
Price: Rm2500 for myvi
Other car model also available, pm and ask
Improve Propex Sport Lowering Absorbers For Myvi
For sport user
Price: RM 600.00 (Cash & Carry)
Eibach Pro Kit Coil Spring For Myvi
Lower your rides 20mm
Enhance car handling, comfort, stability...etc
Price: RM 780.00 (Cash & Carry)
Note: RM 300.00 to be deposit for item ordering
Myvi Performance Disc Brake (M-Tech)
All can direct PLUG AND PLAY
Package include:
1. 2 cross drilled, slotted disc rotor
2. 1 set of ceramic brake pad
Size: Same as our original disc
Its vibration free
Enhance braking & Safe
Price: RM 450.00 (Cash & Carry)
Myvi Normal Brake Set
1. 2 normal disc rotor
Price: RM 350.00 (Cash & Carry)
Brake Caliper
Price: RM600.00 per pair
Here is the package price:
Item 1 + Caliper @ RM 800.00
Item 2 + Caliper @ RM to be confirm
Note: All item required deposit of RM 250.00 for stock ordering.
PM us for any enquiry
Note: Other car model also available, Pm and ask
PM or SMS us to 012-7515 653 or 012-903 8807 or 012-308 6011
V Zone Motorsport
Warranty 1 year
Item is serviceable
Note:
Inverted
Mono Tubed
2 years warranty
For sport user
Package include:
Its vibration free
Brake Caliper
V Zone Motorsport
