standartplast STP soundproofing product and solutions
Now we have the best in market soundproofing solution for you. Reduce noise, increase comfortability. A better ride is always what we want :>
Detailed install process by EA Autoworkshttp://forum.lowyat.net/topic/1543840
http://stp-distribution.com/
INFO:
Company info
Product InfoStP history perfectly reflects all the changes in the last 30 years of the world: In Soviet Union times, our company, people and engineers were involved in research at highest levels* to create and produce damping and acoustic materials for military applications. The need to have perfect products (army and navy approved) was at the basis of the job in those years and became a staple part of StP culture. StP, as a private company, was founded in 1996 and focused on research and development of damping and sound proofing materials for automobile field ever since. Today, StP consists of 5 plants, over 1’000 employees, Scientific Research Lab, Chemical Department and Acoustic Lab, all with latest technology and machinery needed to win the challenges of the global market.
PRICE: Vary from each productEven though most of us do not take any time to think about the sounds that surround us, we cannot neglect the ever increasing amount of noise pollution in today’s world. Every sound that we hear affects us in a certain way – pleasant, unpleasant or even harmful. Julian Treasure explains the effects of sounds on us and how it affects our health – we’d like to invite you to take a few minutes and watch those two short talks.
While driving or as a passenger in a car we experience a large amount of noise generated by a number of sources:
Vibration of the engine
Vibration of transmission
Vibration from the road surface
Airborne sound of the engine
Exhaust and injection system
External noise (tires on the road, other cars, wind, etc)
The two basic ways noise penetrates into the saloon of a car is via vibrations of the car body and airborne sound entering the saloon, we have designed specific materials to tackle each area:
Vibration absorption: These materials are mounted on the interior of car body and have following benefits:
Absorbing vibration of the car body
Sealing properties of these materials prevent car body from corrosion
Increase thickness, strength and rigidity of the car body adding to safety in case of an impact
Sound absorption: This group is aimed at absorption of noise from the sources and is meant to be mounted near the engine and wheels, the benefits are as following:
Absorption of unwanted noise
Heat insulation
Sound insulation: Meant for protection of the saloon from the external airborne noise and is applied to the doors, etc
Insulation of saloon from unwanted noise
Heat insulation
Moisture resistant
Sealers: These materials are for tight sealing of wire holes, contacting elements of interior and are meant to reduce squeaking and sound penetration into the saloon.
The application of all the materials is easy – everything has a mounting self-adhesive glue layer and could be done either on your own or with help or a professional installer / dealer. The installation on a car is usually done with a combination of a few materials from different groups and is heavily dependent on the car model and make. We strongly advise you to contact your local distributor that would advise you the location of the nearest dealer to purchase the materials as well as which specific materials to use and the quantity needed for your car.
An effective installation of materials would have a number of benefits and would dramatically change your in-car experience, by reducing the level of noise you would achieve the following benefits:
Increase in comfort
Increase in quality of music / radio / CD you are playing
Increase in safety
Heat insulation
Moisture insulation
Corrosion prevention
All of our materials have undergone quality certification and are chemically safe.
INSTALLATION: depends
howiechoo 012-767 1360
CLICK HERE FOR MAP | CLICK HERE FOR MORE PRODUCTS
