[WTA] what is this box ? found on viva 850cc engine bay
navz
102
Ipoh
I dunno how to explain well so i include pictures for my question..
This is the box that i mention..
the red round mark is the join with red round upper picture.
thx...im guessing this is oem fuel regulator..but im not sure..hope anyone here can share with me..thx
xtremeleo
3,247
464
its the fuel vapour container, when it has contained enough pressure in the canister, it will channel the vapour into the throttle for combustion. a method to further save fuel
navz
102
Ipoh
sifu... can i disable it and take it out..replace with adjustable fuel regulator..
xtremeleo
3,247
464
DO NOT take it out, u can simply add an adjustable fuel pressure regulator witout taking the unit out sir. err, what have u done dat makes u think u need an APFR anyway?
navz
102
Ipoh
sry do u mean canister = fuel tank ?
currently..i already install afpr(for turbo purpose)..they performance shop kinda disable it already..but the vacumm hose still attach at the box[fuel vapour container]..they let the hose to the fuel tank not connected to the fuel tank[same like the 4th picture i uploaded..because..they use 5th picture i marked to do the afpr return line..they take out this thing(pls see below picture) from fuel tank and do the return line there..cuz viva dont have return line(they also modify my fuel rail in order to install afpr.and i use it for 5 month..1 day..my afpr become like this(pls watch below video)..i asked at zth forum before this..all said its fuel pump problem..i already change..it wasnt solve..so i just bot my car..so now i just feeling not ok with my afpr reading like that..so i tot disable this box MAYBE solve my problem..
plus : before this..when i want to fill fuel in my tank..when i open the fuel cap..i feel some pressure when i open it..now there is no more pressure when i open the fuel cap
ps: now i totally diy my car since i bot myself..never send to any shop anymore..
YouTube - viva fuel pressure dropping
xtremeleo
3,247
464
disabling the box (box=canister=container, canister isnt fuel tank fyi) wud not solve ur problem sir, are u still using the original ecu? have u rewired the power supply to the pump? if u havent for both, please pm for more detail, tq sir
navz
102
Ipoh
im using works fpr..already send the fpr for waranty..got brand new 1 but still the same...meter also changed..still the same..
xtreameleo ugpm
xtremeleo
3,247
464
as my reply for ur pm, its not a pump issue, nor it is an issue with the fpr sir
navz
102
Ipoh
true..already change pump..and uninstall the black box..still fpr reading the same..omg
snoop-pie
95
if im not mistaken, viva, kelisa, myvi have no original fpr, there's is no return line. so there must be a bleed valve inside the fuel tank mounted near the pump. when u want to rise up the pressure by tightening your WORK fpr, the xtra pressure will bleed back into the tank. u need to disable the bleed valve 1st( IF U HAVENT DONE THAT) just my 2 cent
egb18c
922
94
kuantan
what he said above is correct,need to do a T,one hose is from the fuel pump,the other one to the fuel fail and the other one for fuel return to the tank.
charcoal canister wouldnt do any harm as ive took it of from my sr20det.just menyemak in the engine bay.
I thought it would be good if we can have a thread to share experience in using suspension. Many suspension including OEM nowadays do not last. And for some of us, we love to just compare many different ones and get the best one. But that is an expensive hobby! So let us share here. Details to share are:
Car:
Brand and model: (suspension brand and model)
Durability: (no of years it served you before soften or scrapped)
Roads used on: (smooth, bumpy, gravel etc)
*Optional
Comfort...
