WIRA Manual Transmittion Gear Oil Change.
hoskhong
Hi ALL
need help from yours about the gear oil change,
i know there was 2 nuts need to unscrew, one is to release the oil and one is fill in.
can some one guide me to locate this 2 nuts ? will appliciate if can provide photo
thanks a lot
ftzone
full throttle zone
5,339
141
Penang, Prai
www.ftzoneracing.com
1st you can't just jack up the car to change the gear oil. the car must be horizontal position.
2nd you'll need a hand pump to fill up the oil after you have drained the old oil. (because the damn hole to fill up again is small... pouring oil from a can / bottle won't help)
3rd, labour charge in workshops to get this done is fairly cheap. <Rm10.00 + they will properly dispose your old gear oil. =)
DareDan
724
117
sorry tunpang lalu...how often should we change our gear oil? and which oil is better?
Maxx
2,072
42
PD-Putrajaya-KL
www.zerotohundred.com
i think better go wshop. change gb oil usually cost less than RM50.
my friend just done, 1.3 satria. since his gear (1,2) hard to engaged, only RM40 plus with normal gear oil.
ylkien
499
KL/PJ
Bring your own gear oil there...try getting fully synthetic (brand redline or something)....
amad108..
418
5,018
change every 40k km for manual, auto i think longer coz got filter...
i tried fully synt once, very good at the beginning but it cant last long, normally racing car use it coz it fully protect but for short period time... so i just use standard now which multigrade..
I'm buying adjustable pulleys for my Colt Gti 4G93 DOHC with CAI and exhaust 2. 1/4", searched topics in the forum but have found.
Want to know what the best setting to increase the peak power at high rpm?
Can increase the peak power of the 140hp @ 6500 rpm for a rotation greater than 7000 rpm?
How many degrees do I need to forward the admission and how many degrees late to escape, have a higher peak power at high rpm?
Looking forward to the best setting.
