I had a wira 1.5 auto fuel injection when ever I climb up hill I press down the throttle the engine go on. Can anyone pls advise me what happen do I need to clean up the throttle sensor or ecu problem?
When full throttle do you get any other side effect like choking or stuttering? Possibly one of the sensors need checking. Also which Wira is yours? VDO or MMC?
have to check with computer lh bro.
happen to my friend wira before but his is 1.6 model.
in his case its the knock sensor which has its connection not good.
nothing isnabnormalnabt the engine running.
hi i have issue also on check engine light. the diagnose appears “isc servo valve / iac v. pos. s/circuit” . the mechanic said i need to change the TB around 380rm? do i need to change? because i read mostly issue on proton wira was sensor need to replace. thanks who will answer.
Would like to enquire solution for my camry 2.4 yr 2002 model.
I have been experiencing a problem n i hope someone could help point me out the solution.
Problem usually when i start the car. I accelerate the pedal but the car doesnt immediately move, however the rpm increases and then suddenly after few seconds it jerks and moves..
i assume the jerk is due to high rpm, but WHY do i experience late respond from the car?
Please also point out any reliable workshop that...
