im not sure if its a super medalion ..the picture will be like as below ...since it came with silencer so i thought is alrite to put that..seems like silencer is not recommendable..i think i shud just have it pulled off ... thanks for the info ..
Yes. This is the one. I am using it too...Trust me. With silencer, you only able to drive normally & you can't press your car to high RPM for NA car & can't have boost for turbo car as both will harm the engine.
What's your purpose on putting the silencer? If you want to save from roadblocks, I suggest you can install the Apexi or Arospeed exhaust bypass valve where this is totally silence & u can use it when passing by roadblocks.
My suggestion is just let it be as with silencer, d sound sucks bro...
And what if someone let you hear blow-off sound bside u while u on silencer & u worried to boost your car? Hehe....
---------- Post added at 09:44 AM ---------- 6 hour anti-bump limit - Previous post was at 09:42 AM ----------
Does the silencer harm N/A cars as well?
Generally it will hard NA car as well...Don't shoot me ah. Any sifu? Correct me if I am wrong
