WHY Blank rotors are better than cross drilled and/or slotted
HKS-GT2835R
1,193
83
5,148
kelate
While looking up some information for my car on the HT forum I found a great thread which you guys might find useful.
<<I'm posting this here too as well as the Tech. Misc. Forum because this really affects people in here the most and I care about your safety because I have seen too many people get hurt by negatively affecting their car via modification and I feel braking is a VERY important system for this.>>http://honda-tech.com/zerothread?id=1437507
Ok I'm hearing a lot of conjecture, and people are STILL blowing money on ****ty rotors, so I will tell you all why blank rotors are better.
The reason for the creation of cross drilled rotors initially was to remove the "gasses" from the brake pads. HOWEVER, most of your modern brake pads (Axxis metal, AEM semi-ceramic) do NOT produce gasses when heating. This was on bad brake pads used in the 1950s and 1960s. Back then, asbestos was also used, and we dont use that either.
The other reason is so called heat dissapation. I don't have my physics and thermo books with me, but the logic is that the holes in the rotor are suppose to allow the brake pad to cool. So...air gets into the rotor from the inside of the vents. If you have a back rotor which is solid, air gets into these holes how? If your stopped, you are leaving air inside these holes sandwiched between the pads, thus creating air with a rising temperature. Its increasing in pressure from the heat, which I guess you "could" call a gas that would affect braking. So the cross drilled rotors do not remove any gasses formed by brake pads (because there are none created anymore) but could possibly inhibit the creation of "hot spots".
Cross drilled rotors have LESS contact area because of the holes.
But if the rotor is cooler, its better, right? Well no, because these rotors are not cooler. THe heat is generated from the pad/rotor contact. What removes heat the most effectively? When stopped or moving, the pad transfers heat into the rotor because its made of cast iron. the rotor has a lot of surface area and even vanes in it. But the little holes allow air in this surface contact, and you can transfer more heat into a solid big ass chunk of cast iron more than you can into the air. Don't believe me? Touch some steam at 150 degrees, then touch a piece of hot metal which is at 150 degrees. Which burns your hand? the metal. So let the heat transfer into the metal, because since it has so much more surface area, dissapates better.
Even racing teams will reccomend AGAINST cross drilled rotors:
http://www.livermoreperformanc....html
Companies that sell cross drilled rotors that are redrilled may not be structurally sound. I have actually seen pictures of rear Integra rotors that have had hairline cracks turn into the rotor actually breaking apart!
Do your homework. Even Porsche and Ferrari will admit that the cross drilled rotors they use are for looks. So if you are one of those kids who thinks the little holes look cool, get a name brand drilled rotor like Ferrari does. The REASON Ferrari's 'holed' rotors are alright to use is because they are CAST with the holes in them, so they are not actually drilled into cast iron rotors. Cheap drilled rotors are not safe, and even the good ones are not necessary. Why do Ferrari do it? People THINK they want it, and it sells. If you don't believe me, go into the business world. You will learn that pretty soon, you can sell utter **** if people THINK its better.
Information I gathered from http://www.pdm-racing.com/prod....html
says:
"KVR Crossdrilled Rotors
Why should you upgrade to cross drilled rotors?
Simply stated, the function of any vehicles brake system is to stop the vehicle. This is accomplished by absorbing the kinetic energy stored in the moving vehicle, and converting it into heat. The friction caused by the brake pad rubbing on the rotor is the source of this heat. The more quickly and efficiently that heat can be absorbed and dissipated, the more quickly and efficiently the car will stop.
There are several contributing factors to this heat reduction. One of the most common sources of heat is from the gases produced by the bonding agents of the brake pad burning off. Under severe braking, this can actually produce a boundary layer of gas that pushes the pad away from the rotor, which can lead to excessive brake fade. The cross-drilled holes or slots in a rotor provide an escape path for these gasses (de-gassing or out-gassing are common terms), and allow the pad to stay in contact with the rotor. As well as de-gassing, cross drilling or slotting will provide better wet weather braking as water is swept through the holes, or down the slots.
A vented rotor can be viewed as an air fan. When in motion, the vents draw air from the center of the rotor outward. This air flow, over an increased internal surface area, effectively dissipates rotor heat. Cross drilling adds to this air flow, as well as providing additional rotor surface cooling. "
This company is just telling you that the rotors may be cooler, however they fail to mention that the holes really do create a more than substantial decrease in surface area, thus less braking, thus less heat created, thus the less heat CREATED will leave the rotors cooler, the holes barely do anything! Its the less braking lowering the temperature!
Slotted rotors-
Find me a company that uses stock slotted rotors. They remove brake dust, but if you study braking systems, you find that with modern cars, flat blank rotors and semi-ceramic pads, the brake dust causing the rotor to slip on it is almost non-existent. But the brake dust doesnt need all those lines. Notice how most front brake pads (and most back) have that line down the middle to give essentially two bite points. If OEM or racing companies found it to be a benefit, they would do it.
Here is the link to the thread: http://www.honda-tech.com/zerothread?id=1437513
what do you say guys?
TitanRev
You think I print money?
Mar 3, 2005
8,180
3,678
Well, if slotted or cross drilled disc is not better than blank ones. Why would big companies like Brembo, AP Racing, AMG, EBC, StopTech, Grippen, TRD, Nismo, Wilwood..etc want to produce this kind of brake system upgrade? :hmmmm: I think they did take their products and put them into a series of heat test before they sell to customers. As we all know that a set of brake kits from these companies is not cheap they cost almost thousands. If its just for looks why its so expensive ?
I do saw a lots of cross drilled disc used in racing. I'm making the above statement on my own opinion and observation. Didnt meant to pick on anyone and no hard feelings. :smile:
KryPToN
809
Selangor
hhhmm... interesting discussion. however i have no input on this. i hope others with more knowledge on this can help on this issue.
errrmm... anyone noticed if the F1 cars are using 'blanks' or 'crossdrilled & slotted'? probably it would be a good indication there since they are mainly looking for better performance instead of cosmetics aspects of the sport...
TypicalGuy
1,111
if black blank rotor..i believe it will be very very good ler
SkYwAlKeR
Over 10,000 RPM!
10,139
300
5,183
ePoh ~ malacca
crossdrilled good because the water on the disc can be dispersed away mah... like how the bunga on tyres work in wet...
that is why some say non-crossdrilled or slotted disc is good... they work same like slick tyres,.... more grip... but works best on hot weather...
HKS-GT2835R
1,193
83
5,148
kelate
none taken (which how it shud be).
opinions man..wanna get lotsa opinions so that we know what is and what's not.:cool:
yes, braking upgrades do cost both balls, and it is worth it..but IMO even if its just for looks it will STILL be expensive.:biggrin:
ross drilled AND slotted is overkill but it looks impressive.
here's the deal ya..you can and shud use plain OEM rotors if you aren't doin' any performance driving (competition).
You can get slotted alone or cross drilled alone but for your driving needs those are overkill too.
the slots or crossdrill holes "outgas" the heated gas built up in between the pad and the rotor when you drive aggressively and are on the brakes under a lot of heavy braking like in a lapping session or drifting (?).
You don't build up the gases and you don't go to those high brake temps in street driving.
BTW braking distance in terms of rotors is determined by the size (diameter of the rotor) or surface area provided by the rotor and the clamping force of the caliper (number of pistons). The slots and crossdrills prevent brake fade...they aren't directly related to stopping distances per se. If the temps and outgas build up get too high from repeated hard braking over many laps, then stopping distances and brake lock up is affected. That's when the slots and drills are important.
Be careful about advertised crossdrilled Brembos. Some shops get the OEM Brembo replacements and then drill them and sell them as "crossdrilled Brembos". The real crossdrilled Brembo rotors have the holes created from a mold...there's no actual drilling involved. Drilling creates more stress risers in the rotor and makes it easier for cracks to form at the holes over time since the structure of the hole is weakened.
Yes Brembo is one of the best rotors around but if the diameter is the same and you don't need the outgassing performance, why bother pouring your money into it?
i've read somewhere that it actually hurts wet-weather braking. them journos got this hi-speed photograph of it and it shows that water gets in them holes/grooves, which increases slippage. and IIRC those holes/slots are for brakedust?
keep it comin' & keep it clean, guys. this is great stuff
sam1741
1,188
well when i lean physic..
the law said : the larger the contact area, the more friction generated
i think this means blank disc are better
but i think the 'holes' are for rainy days...
like..anyone ride bikes before knows.. when rainy days your disc brake wont 'eat'.. cause one later of water on it.. so here where's the holes comes to work...
(dono how to explain anyone can help me out?)
just like why long long time ago F1 tyre is black rubber one with thread or any pattern, (larger contact area), but during rainy days they will use tyres with lines (to channel the watter away.. raining days there is one layer of water on the road)
gavan
1,408
Shah Alam
i do not agree with sam's opinion as i was riding a motorbike before, full disc...and the braking was not too good when it was wet. even both my disc was cross drilled, the bike was not braking too good when it was wet and cold, but once apply some hard pressure on the brakes and the disc heats up,the braking improves ;) so erm, beware when you are riding fast and your brakes are not working, just apply light preesure till the disc heats up then the braking will improve :D
will elaborate more when im home :D
HKS-GT2835R
1,193
83
5,148
kelate
agreed..my bike got cross drilled double disc up front, and it sucks when wet.
when heated up properly, say..2~3 minute of riding, then it'll be a BIT better.
my guess it's due to stainless steel discs. cast iron rotors are better in wet.
zamnov
316
HKS-GT2835R,
Great post for knowledge sharing.
I was contemplating of getting either slotted only or crossed drilled and slotted rotors, but this post really got me thinking hard!!! Looks like cross drilled and/or slotted rotors aren't a necessity for me now...
BTW, one team that entered the MEM race this year used crossed drilled and slotted rotors throughout the race. There was some cracking in the disks after the race ended. Not sure if it was due to the race being dry at the beginning and ending up wet at the end...
HKS-GT2835R
1,193
83
5,148
kelate
zamnov, my 0.02, go fer braided brake line & hi-performance brake upgrade man..
SkYwAlKeR
Over 10,000 RPM!
10,139
300
5,183
ePoh ~ malacca
i've read somewhere that it actually hurts wet-weather braking. them journos got this hi-speed photograph of it and it shows that water gets in them holes/grooves, which increases slippage. and IIRC those holes/slots are for brakedust? keep it comin' & keep it clean, guys. this is great stuff
i thought if water is guided away from the disc, hyproplannning would not occur when ur brake pads come in contact with ur disc??... thats why they have slotted and crossdrilled disc..
besides, dont crossdrilled and slotted disc cools off faster compare to normal ones??...
HKS-GT2835R
1,193
83
5,148
kelate
well, i read that somewhere..that's why i'm here to know whether it's crap or truth..:tongue:
i still believe them holes n grooves hurt wet weather brakin'..but i might be wrong!:biggrin:
IMO because they heat faster too..
urm, since there's less metal on the drilled/slotted discs, that means lower maximum potential heat holding ability. youre taking metal out of the rotor when they are drilled, true?
this is an extreme and not exactly scientific example but, lets say you have a 16" rotor, it holds a lot of heat, it takes a lot of braking to max out its holding ability and then turns red.
well if you drill/slot that rotor it might only have the same amount of metal, say..as an undrilled 15" rotor? which if you gave the same beating to would be glowing red a lot quicker, because it doesn't hold as much heat.that's why i say they heat faster too.
IMO this cold-hot-cold lifecycle will shorten out OEM discs life, if they're slotted/drilled, yes?
HKS-GT2835R
1,193
83
5,148
kelate
here's a race dodge viper on blank disc..
note the small slots on the discs, which i think acts as thickness level indicator to the discs
plz excuse the size..
heres another interesting shot...
porsche gt3 cup car, front brakes.
small slots. hmmmm:bath:
BAR F1 brake discs for interest sake:
for racing, well..bigger is better, as ppl wud say..:tee:
Hi all, can anyone tell me how to best fit your safety harness to your cars? I'm thinking of finding & fitting my EG hatch with 3 point harness ( so at least can still have 2 passangers at the back loh ) pls do see my pic and hive comments / ideas pls. Thanks all!
http://img296.imageshack.us/img296/4053/safetyharness0zv.png
the 3 point harness ( the one from the front bucket seat slot points ) is fitted between the...
