Where to do custom made anti roll bar
Vigilant
28
Anyone knows where to make custom made anti roll bar ? The one with with ultraracing is too thick , so i want something thinner.
jerrysiow
407
146
Seremban
What is your ride dude? What diameter to you is thick? UR bar got 16mm which is normal and not consider thick.
Vigilant
28
Yah but the model I want only has 19mm. It's a prius.
jerrysiow
407
146
Seremban
Nice ride. My advice is get those reputable brands instead of chap ayam. This is because if the ARB has not gone through a proper design, it might not able to sustain the stress and it might break into pieces. This might endanger urself.
Vigilant
28
so say i want to import the bar , how do i go about doing that?
Vigilant
28
Already got the 19mm , didn't like it. Felt too stiff and like it jumps over bumps instead of absorbing it.
There's a reason why cusco , TRD, whiteline chose 16mm instead of 19mm.
mADmAN
1,840
547
u can actually custom make it at ultra racing themselves... just contact them about it.
take note the cost will be significantly more.... dont be surprised if it costs the same as the cusco unit iszo posted.
their mass produced items are cheap... custom work are expensive
UR also can do custom bar according on what u want and what u will pay
Similar threads   Forum
ICE -In Car Entertainment
S General Talk
  Similar Threads
S General Talk
Dear all,
I having problem with the GearBox (Wira 1300cc), need advise change Recond or 2nd GearBox?
Cost only different RM 100 for 2nd & Recond. 2nd cheaper RM100. So which to take ?
Current GearBox bearing spoiled, Gear oil keep coming out after replace the new driveshaft oilseal..... but funny thing is the GearBox housing no crack.
Hight percentage is the bearing inside of the GearBox causing the Gear oil keep coming out after new Gear oilseal changed.
Thx.....
