What Standalone ECU is better?
frecoz
247
www.tagged.com
--i'm planning to buy a standalone ecu this month.. but i have no clue.. which is better..
i heard many of ecu, such as freedom,mines and etc.. is it enough for 3k including dyno?
--what is motec,haltec and etc? is it standalone too?
--which is better between standalone@e-manage(black)@safc(any racing version)?
are all of these compatible with 6 speed (c160) gearbox?
--is it ok to install standalone even my cam,piston,clutch still standard one?
any different from stock ecu? how about the safety for the standard engine? thanks..
by the way, happy to login back as my account inactive and i cant login.. hahaha.. luckily can be login back..:rofl:
vh-101
546
32
I think any standalone is good. It all depends on the tuner..
ryzzal
432
if everything stock standard, dun bother of using standalone...
just go for emanage blue that is way too good for ur stock engine...
j_l200s
338
74
3,028
-3k obviously will not be enough for standalone (new) itself, not to mention the installation + tunings. Yes, motec/haltec/microtech are all standalones and they dont come cheap. Prepare at least 5k for microtech. :smokin:
-e-manage, safc I/II are not standalones. they are piggybacks (which means u still need your stock ECU).
-standalones/piggybacks can be used regardless of what gearbox u use.
-stock engine (i assume yours is BT) would work nice with e-manage. furthermore, i think e-manage + installation + tuning would be less than 2k? can someone confirm ~market price?
-if u plan for future mods/upgrades (maybe higher profile race cams or turbo), it would be great to get a standalone but i can assure u that 3k is not enough at least for a brand new one. a used one maybe la but not sure market price oso.
-if u got 3k as budget, i suggest u go for another piggyback called Unichip Q. i think it's around 2k+ including installation and tuning. From what i know, it out-performs e-manage blue (not sure about e-manage black/ultimate tho).
maybe other forumers can share their point of view. this is just another 2 cents of mine. good luck!
glanza
349
5
kl/kelate
maybe u can get a used adaptronic standalone ecu with 3k budget..made from aussie, some people in here has offered me.
Sil80-13
1,215
44
1,648
Wow. interesting...Who want to sell it? Still attach to SilverTop or BlackTop? And who is the tuner & installer for this product if buy from the seller? Hehe....
Give some info la bro :biggrin:
frecoz
247
www.tagged.com
is it ok for me to get used standalone? i have heard someone said want to sold freedom ecu for 2.5k.. dyno for 500 doesnt enough? how much actually for tuning and installed? which ecu were the best? because i think, after having some cash, i prefer to upgrade the cam+piston+trd clutch(because for road used).. hehehe.. by the way, mine is blacktop..
i heard emanage can only set 16++ but ultimate 36++? is it true?
how about the ignition & injector harness?? did i have to installed it too if i get standalone??
how about fpr? what is that? because i read somewhere and he told that 'fpr'.. thanks guys..
t-la
1,080
20
5,138
secret place
hi, can i ask u somethin'...
what is ur main purpose in getting standalone?
what is ur current setup?
alvinT
222
every different standalone ecu are for different car make...
such as power fc works wonderful on RB engines...they are made for them...
motec and haltech are way to costly...
i would guess u go for piggyback 1st for now...even if u upgrade ya car in future...those piggyback are still able to support such as e-manage and unichip...unless u got the budget then go for standalone...
but with ya budget, i don think it's enuff for get a standalone plus tuning and dyno...
frecoz
247
www.tagged.com
im getting standalone because i think standlaone is just fine to tune because it make for one car only, not universal like emanage and safc...=)
my current setup:
-8.8 cable plug
-volt stabalizer
-gound earth wire
-twin muffler with 2inch piping
-heavy duty clutch(flywheel and clutch cover still standard)
-open air intake with bearing turbine
-air compressor
-lightweight 17'' rim with sport tyre
-standard superstrut but have change the coil spring
-fuel regulator RJ type
(other thing doesn't involved in this topic such as rsm,rpm with shift light etc..)
how much it need to install standalone?
and how much to install emange?(i prefer ultimate but i also want to know blue one with the harness and everything) thanks...
cuscostrutbrace
987
62
3,028
Stand alone and tuning will cost more than rm4000 if bought new..If your engine is stock and did'nt bother to remove the rev cut,just install piggyback...save you money..
Stand alone ecu prices depends on their specs...some are plug and play(japanese standalones) and some are wire-in(australian,europe,us standalones).With wire in standalones,you can get more flexibility,more options.
ryzzal
432
as i already said earlier, with ur 'set-up', its mearly stock std... dont have to bother of standalone coz what i can tell u, u will either blame standalone itself or the tuner coz ur car cant go 'fast' as what u expected to be....
this is all because of ur stock 'set-up' in which emanage can give the same results as standalone....
for emanage, i can give rm 1450 package with ignition harness, installation & street wideband tuning...
remaining rm1500 u can get other performance parts or send ur head for port polish or anything u wish...
another thing u need to consider also if u go for freedom or unichip, how tuners can tune ur management... let say if u doesnt like ur tuner set-up, and very limited tuner available and cant source other tuners, will u sell back ur management? or live with sucks performance?
sy_omar
287
Kinrara
my opinion... upgrade ur engine part 6 speed gb .... make it durable, enhance brakes etc... then u can touch electronic.
aziziell
1,508
6
my opinion with that setup piggyback also no need laaa...use stock jaa..hehehe...but stand alone or piggy back can save fuel a lot oooo...
nappx
2,532
185
5,163
kLaNG-kEy_tEE
if u ask me..what i'm saying is..
do your internal first...change to durability parts..ie: conrod, high performance bearing..etc lah..
if you have extra money can go to standalone...remember..cost of tuning..any changes to performance part should be tuned again to get actual performance...last time i buy haltech but decide to sell it when know what is the problem...which involved with money
j_l200s
338
74
3,028
FPR = Fuel Pressure Regulator. u already have it (-fuel regulator RJ type)
Not ALL standalones are for specific cars except for Apexi's Power FC. Popular brands like motec, haltech, microtech and adaptronic for standalones for universal engines. i personally like adaptronic tho. they from australia, they are cheaper than most standalones and we got few good tuners in sunway/KL.
i agree with sy_omar, ryzzal and nappx. mod your engine first with parts that can provide u real HP/torque figures. For eg. extractors, cams, pulleys, valves and valve springs, port-polish head, 6 speed gearbox. OR EVEN BOLT-ON-TURBO!!! 17" wheels won't give u HP tho :p
After that only install piggybacks or standalones. u don't wanna re-tune each time u made some mods. if u got the time and money then i got nothing to say la.
i think piggybacks still be able to accomodate the i mentioned mods above. unichip is obviously better compared to emanage blue but not sure about ultimate tho. they still work nicely for daily street driving and playing around once in a while.
don't be disappointed if u get 5-10 HP by spending 4-5k on standalone with your current setup. u can actually get more than that HP by using ur budget on your engine mods first :rofl: noticibly on JASMA extractor, pnp head and oversized pistons. they are proven :smokin:
glanza
349
5
kl/kelate
agreed with they all..frecoz, i think u shud improve your parts first..do your head first, with 5k spend to your head, yam..yam..speechless huhu:evil:
frecoz
247
www.tagged.com
thanks guys... looks like everybody want me to spend on head first, then the head will it be.. =) for now i think i just want to put emanage.. ^_^
n0th1n
1,161
12
japan
junk-dealer.blogspot.com
hehehe.
"? or live with sucks performance?"
oit, im using freedom now weh!!!!
let me give different opinion.
toyota restrict our engine's performance about 10-15%. how? they downtune it using the ecu. u want to unleash the 10% performance? want 100% performance, go for management, whether it is piggyback or standalone. 165hp at flywheel at factory, 10% is 180hp at flywheel, 130hp at the wheel, will increase till 143 hp at wheel.
in order to get that so called 10%, tuning is another "pecah kepala" issue. mechanical tuning, and electrical tuning is related but different specialist. cam setting, timing adjustments are some example of mechanical tuning that sometimes, one person will say setting A, other person will say setting B, but both are just adjusting the distributor only.
durability is the issue after that.
good, u are doing ur homework. dont buy stuff that u dont know the functionality, cost involved and the after effect (like me lah!)
frecoz
247
www.tagged.com
hehehe.
so u r using freedom? any different from emanage?
actually i want to put standalone because i want to save my standard 6speed ecu.. if anything short circuit or whatsoever, i still have a standard backup ecu.. thats the main purpose actually..
r u agreed with me by 1.5k to spend on emanage and other 1.5k spend on my engine?
or just go for standalone?(which means expensive for nothing?) hehe.. thanks..
Eeeee. Yeah. It's Nurburgring!. It's the Green Hell and I'd know by now you'd be really envious of my experience. I'm sure I'm not the first Malaysian to have been there, and driven in the 'Ring as I personally know of a few friends who've done it, and I know if you are reading this, you would have already driven on the Nurburgring too, except that it's...
