wastegate do bov job
wasteg4te
154
9
jb
this pic im took from nismo website.
[IMG]http://i375.photobucket.com/al...wastegate? or bov correct me if im wrong....
Maxx
2,072
42
5,148
PD-Putrajaya-KL
www.zerotohundred.com
seems like using it as boost regulator.
it vent off excess boost from the preset boost.
see the vacuum hose, it go thru boost solenoid.
jinkl
4,623
376
3,183
wastegate and bov's are mechanical + pneumatic
if understand the basics then u can know how he did that
yes a wastegate can be used as a BOV , maybe he is wants to run at super high boost and wants a super stiff one
by fitting two hosses , up and down , tht bov would not open because two sides are pressurized , once u leave ur throthle, the top which is tapped from intake manifold will be running in vacuum since TB plate is closed, while the bottom side vacuum hose is still filled with boost, thus the wastegate will open up to release access air , but remember that wastegate/bov will not open unless it reaches the pressure of the spring rate.
lets say that wastegate is 0.3bar rated , u r boosting 3bar , the moment u let go ur accelerator
, the wastegate will work as a bov n let air out , but it will immediately shut down when it reaches 0.3bar
got it ?? its just basic engineering :D
azameel
152
owh,
its like a normal bov plus spring inside.
By the term high boost, how high could that be?
i think the psshh sound is still there.
try to put waste pipe there and see what happen:biggrin:
i just tranplant mivec-MD gen 1 to my car n stil running in condition. i was trying to engage my mivec yesterday n found that knocking sound happen while mivec open arnd 5.5k rpm onward during slow acceleration but if fast acceleration the knocking sound just happen at the period of mivec kicking which is 5.5k-6.5k rpm only .. besides, my car r difficult to start when my engine was heat...your feedback will be appriciate...
