Waja 1.6 auto gear indicator
sifuconman
25
503
Hi
I have a 2005 model Proton Waja 1.6 automatic. Recently I notices that when I switched on the head lamp the "R" indicator light was on slightly when I was driving the car, and the right signal light blink faster than normal when I make a right turn.
No such problem is observed if I do not switch on the head lamp.
Any one encountered similar problem and any suggested solution ?
Thanks
Hi
Thanks
Not too sure on the R indicator, but signal lights blinks at different speed could means current unstable. Just like if one signal bulb blows the signal light blinks even faster. Maybe you may require additional earth.
sifuconman
25
503
Thanks. For your information my right signal light only blinks faster when I switch on head lamp and the "R" is half lighted. Otherwise no problem
Then check your right side wiring. Even cleaning the bulb contacts (front and rear) sometimes help as the contacts can oxides and less current goes thru"
sifuconman
25
503
Thanks. Will check that
Note : The right signal light blink faster than the left under the following conditions :
1. Head light is switched on and at the same time
2. "R" gear indicator is half on even when I am driving and at the same time
3. I applied the brake.
Oh!, now more things coming out. R thing really no idea since you are driving it should show D.
Apply brakes also draw current like switch on head light is 55w x 2. Brake bulbs as 21w each x 2 and plus 3rd brake light, therefore quite a lot of current draw too.
sifuconman
25
503
Yes the "R" indicator is not fully lighted when driving whilst the "D" indicator is fully lighted.
sifuconman
25
503
I would like to report that I had managed to solve my auto gear indicator problem. I found the left side position lamp's contacts were oxidized. After I used a sand paper to clean the contacts and reinstalled the position lamp the problem vanished.
Thanks all for the help rendered !!
:adore:
:adore:
So it was a contact problem.....:biggrin:
sifuconman
25
503
Yes it was a contact problem !
---------- Post added at 10:56 AM ---------- 6 hour anti-bump limit - Previous post was at 10:52 AM ----------
Yes it was a contact problem ! I guess there was a large current drawn when I switch on the light that is why the problem only came up when I switched on the light !
gunnerzz
Jul 3, 2014
2,109
695
713
38
Melaka
Short question regarding my waja gear indicator;
My gear indicator is not working but the car drives fine. Few days ago it works for a short drive then its down again till today. I am just wondering where does the signal comes from? The TCU or the multifunction/NSS switch?
Hi ppl,
Anyone interested in doin air brush?cost around rm600-700 for a bonnet...location at subang!Interested pm me!Thanks
