What sort of coolant should be used for the Perodua Myvi? The manual simply states to use a high quality ethylene glyvol coolant.
Would normal green dye silicate coolant be compatible?
The normal ethylene glycol coolant is green in colour and contains silicates. What brand of coolant do you recommend that I should pick up for the Myvi from a spare parts shop in Malaysia?
Nowadays the green dye coolant does not seems to last. Within 6 months turn clear already. Have been using Toyota Long life coolant for sometime already. But Red is color....
I knew it... the color of the coolant was pink-greenish which showed there was different types of coolants mixing. The only clue that the Perodua Myvi was supposed to use the newer OAT/HOAT coolants was the recommendation in the owner's manual to use long-life coolant since I didn't what colour the coolant was when it was new.
Then buy back same from Perodua stockist to be safe....
That's pure. It has to be mixed 1 part to 10 with water. You can't use that only la. Not good!
i only pour 1 litre coolant then the rest is distilled water.
Lazy to see ratio thing. :vroam:
Most are 50:50 but have to see what's the instruction at the back.
Premix for a peace of mind. And u probably need to do flushing too since u said it showed evidence of mixing.
My mechanic say toyota red coolant is good, simply because it was "strong chemical" concoction. It would not suit older car as it would "eat" piping and internals and eventually become thinner, and possibly leaking. He claims many such leaking cases would start off through showing powdery corrosion at area of rubber hoses/radiator/engine hose coupling. Since then, I stopped using Toyota Coolant.
BTW, a few sparepart shop dealer I know in Seri Kembangan told me that Toyota red coolant is the most pirated coolant in Malaysia. Please make sure the coolant is ori.
Similar threads | |
