Is there any possibility to change turbo to N/A?If i made this mod will it be any defect to the engine?Have been asking to few mechanics about this n they said the engine might kong..is it true?
All new item i think.SkYwAlKeR said:thus, better get a halfcut... but u'll have to deal with JPJ lo for the transplant...
i saw the RS project from hypertune, they say their bolt on turbo cost rm30k... is it true??... why so expensive ar??
NA-->TURBO = can kaboom1298 said:if it is the from the same series engine, yes, u can swap the pistons easily, and no, metal gasket is not that necessary for NA engine. Normally turbo spec engine has better block, crankshaft, and con-rod. so with all those strong foundations, u can rest assure that your bottom end will be bullet proof, for NA.
Turbo to NA conversion is lots more easier than NA to turbo.
