topic starter should start the discussion ler.. not ask someone else to do the discussion... if got question then ask straight away, maybe all of us here can help. if not the topic is pointless imhoscorpio84 said:Discuss about the modification of Toyota Levin Gt Apex i.....
If throw away the sensor, you can't even start the car. How to go fast?scorpio84 said:opsss...!!! sorry ...lets discuss about AE101 model 1994...the japanese home model. coupe. ....so do u think will the car can run much more faster without the sensor in between the air intake and the engine system.
yeah, remember you saying that last time. something about throttle position 0% and idling the engine won't get signal from air flow?klgauto said:can the engine can start ......last month i forgot to plug in the AFM socket at Acoustic car ....than i start the engine ....engine fire up but the idle speed very low can't even rev up the rpm
no need aftermarket.. just plug in blacktop ecu and a map sensor, kautim, cuz my mech running my car around with a bt ecu before i found an svt ecu.scomatic said:ya lor... How to start engine wo... if without the air flow sensor? :emoticon_U: unless using the aftermarket ECU.
unplug first then start or start first then unplug?klgauto said:you can start the engine but can not drive lar , you can unplug your svt afm an see how lor
