- Feb 2, 2006
- 198
- 0
- 1,516
Seeking help,
1. I have this problem where by, while driving when pressing the clutch to engage gears, up or down, the RPM will dive down to 400-500, causing the car to judder abit. The car doesn't die but i don't think it's normal for it to react that way.
So what may be the cause? Dirtty throttle body?
2. SOmetime the car will misfire. doesn't happen everyday but at times it's a pain. It's like missing a firing phase or something. Would the fault be the plug cables or lack of fuel due low fuel pressure.
For all it's worth, i've change to normal plugs, brand new at less than 20K milage. Tuning is basically worthless as the ecu which is siemens and will reset it self.
Plug cables are aftermarket ones, 10.8mm. then there's the usual open pod air filter and it's a satria 1.8
so whats the catch?
so whats the catch?
