Mivec and Evo 1-3 are the same size = 60mm both can fit a SGTI. For Intake you're limited to the 93T or Mivec. If you're using the GSR intake you'll need to port the intake to fit the bigger TB. Good luck ...
hi, i owned a pajero 2.5 turbo diesel engine model 1996. i need some assistance on the air conditioning system. the car has 2 air conditioning which is located in frontal n back and each has blower n cooling coil. problem is the car is not cool enough during day time about 30'C inside cabin. currently the car has only one condenser wit two fan install. does the car needs additional condenser modifications? need advice pls, it fried me up during day time driving. :( thanks.
