So small cannot be monster. Just Mighty Mouse...Shiettt monster coming.
Mighty Mouse that sapu Wira(Hero) worrrSo small cannot be monster. Just Mighty Mouse...
Mighty Mouse that Sapu CKD LembuGenie A Vent & A DoorMighty Mouse that sapu Wira(Hero) worrr
Sure is metal valves then at RM5 is cheap. Most will charge RM10 or even more...Yes bro, that's what they said, metal air valve. Then RM5 is the price I guess.
Old car do up first time ok lah! Peace of mind....As far as I remember so far:
Steering Shaft Cover -
Perodua Gold Semi Syn Engine Oil - RM65
Perodua EO Filter -
Brake Fluid -
3x Perodua ATF 1L - RM45
ATF filter -
Air Filter - RM8
Fuel Filter - RM5
Fuel Tank Cap - RM6
Fan Belt -
1 set Front & Rear Absorbers - RM226
1 set Brake Shoes - RM28
2x Brake Pumps - RM104
4x Falken SN328 Tyres - RM360
4x tyres' metal air valve - RM20
Alignment - RM20
2x Nuisance Screws - RM90
2x Nuisance Screws Adjustment - RM50
Alignment - RM28
2x Brake Bulb - RM5.50
Central Locking - RM30
If the pedal is going down you need to change the brake master pump already. Remember that day the mechanic tried to flush the brake fluid, the release nipple already jammed with dirt....The labour for all the things change above if not wrong should be around RM420. Those listed are just price of items i bought from sparepart shops.
I haven't change the water pump. Will get it change. Thanks for highlighting. Brake Pump might need to change as well. Since after doing flushing due to previous owner like never changed brake fluid before and got stucked. Now the brake pedal will sink in after braking awhile.
Timing Belt, the seller claim he had already changed. Should I get it check or trust him? Seems he has the old timing belt at the rear as well.
so far that's it la.....flushing the radiator u can DIY.:hmmmm: one of the way to change engine that my future home minister will not nag me....
But not a good way to go with
Will get this 2 changed then. Thanks bro. Anything else I need to take note to change?
But his, the release nipple jammed with dirt. Mechanic took out dig in and clean it out before can flush....so far that's it la.....flushing the radiator u can DIY.
change brake fluid DIY also...use any old bottle shampoo, stick the nozzle inside & pump the old fluid out.
If he does it one by one probably finish in a year.....u can watch youtube, alot of videos of DIY car maintainance..
Saga for sale....o.O, change to kancil edi? Where is your saga?
If your brake pedal will drop while braking = your brake master pump as mentioned by bro Vr. My dad faced this before, the brake master pump is leaking and the brake pedal feeling is terrible.
Yup, I ask Fong the other day, he said is normal cuz that time stucked then after flush is time to change the brake pump already.Sure is metal valves then at RM5 is cheap. Most will charge RM10 or even more...
Oh, ya he told me about cleaning the radiator and see because I told the mech when I drive below 90km/h is fine. But when I drive 90km/h for longer period. My temperature increased above half.so far that's it la.....flushing the radiator u can DIY.
Ya will have a look at it bro.u can watch youtube, alot of videos of DIY car maintainance..
Saga? The Old Saga Ends here. The new saga begins with Kancil projecto.O, change to kancil edi? Where is your saga?
Ya anyone want to continue the Saga?Saga for sale....
Jetta keeping. That time is either the Saga or Jetta goes. So since Saga going, Jetta staying.jetta also for sale :proud:
It was like whether the wife goes or the gf goes.......hahahahahahaJetta keeping. That time is either the Saga or Jetta goes. So since Saga going, Jetta staying.
