Want To Sale "ULTRA HIGH END SUBWOOFER"
SKAANING FLEX UNIT 15'
Excelent Condition
Here The spec:
SKU: Skaaning FlexUnits 15E Diameter 410mm 4Ohms Subwoofer (Per Pcs)
Resonance frequency - fs: 18 Hz
Equivalent volume - Vas: 600 liter
Qms 1,5
Qes 0,26
Qts 0,22
Nominal resistance - Zn 4 Ohm
DC resistance - re: 3.5 Ohm
Effective cone area - Sd: 835 cm2
Compliance – Cms: 0,615 mm/N
Mechanical resistance – Rms: 9,59 kg/s
Moving mass – mms: 127 g
Inductance 1 KHz – Le: 0,98 mH
Force factor – Bl: 18,22 N/A
Winding height – Hc: 25 mm
Air gap height – Hg: 10 mm
Nominal power – Pn: 400 W
Acceleration factor: 143
Efficiency – SPL: 93 dB
Linear excursion (x-max) 8.6 mm
Max. excursion (P-P) 46 mm
Weight: 18 kg
REDUCE PRICE FOR FAST ----RM3250
The Price is Posted To All Malaysian Area
Excelent Condition
Here The spec:
Qms 1,5
Qes 0,26
Qts 0,22
Weight: 18 kg
